Question about DeLonghi Irons
Where can i get a manula for Delonghi stem iron model VVX810
MY IRON GETS HOT BUT NO STEAM IS COMING OUT EVEN WHEN ITS FUUL OF WATER PLEASE HELP
snakehead
  • 1074 Answers
SOURCE: Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Posted on Apr 18, 2007
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
geokohler
  • 304 Answers
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Posted on Jul 24, 2008
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Posted on Oct 07, 2008
SOURCE: i have an elitech steam generator iron but water
I have had this iron for 5 months and only been used 4 times. When I turn it on , there is water leaking out of the iron and the handle is too hot to touch after a few minutes
Posted on Aug 10, 2011
Should the cable from the machine to iron get hot
If the iron is a steam-iron with a steam tank in the base-unit, then steam is carried up the connecting pipe & it will get hot in normal use.
If you put water into the iron itself, then there is only an electric cable connecting the base & it should never, ever get hot. A little bit warm maybe, but never hot.
Best of luck.
Mar 09, 2018 | Irons
Water coming out of steam holes
Either: the iron is not hot enough to heat the water to steam temperature or the internal water-flow valve is leaking so that too much water is getting through. Check the iron is getting hot enough first. If it is then run some de-scaler (as used in kettles) through the iron to try to clean all the passageways. Always ensure that you fully re-flush the iron after de-scaling or you'll damage your clothes with any acidic residue left in the iron.
Good luck.
Dec 04, 2016 | Irons
Can't seem to prime iron to get the steam coming
  • if your having trouble getting the water in the iron to steam, try turning the heat setting all the way up and then add cold water to the resivoir. your iron may not be getting hot enough
Oct 11, 2014 | Irons
Philips steam iron no steam and red tap light is flashing even when filled up with water it's still getting hot and water is boiling but steam fiction not working as red light will not go out
It sounds like the flow holes are CLOGGED with scale inside. To clean it out:
1. Drain the water/steam out the pour-in shoot at the top of the handle, over the sink. Is any crap coming out?
2. Take some VINEGAR and pour it straight into the fill pour-in shoot. Don\'t dilute it. Fill up the IRON to full line. Let the vinegar SOAK the inside of the COLD iron for 15-20 minutes, by placing it FACE DOWN on an old bath towel, on a heat-resistant surface, such as a granite counter top, or metal cookie sheet. Don\'t put the towel on the ironing board!!! It may get stained badly. Let it sit, COLD for 20 minutes. You can swirell the vinegar around by shaking the iron.
Stand it up on its flat end, with the vinegar inside, still. Take some fresh vinegar and dip Q-tips into the vinegar and clean the slots and holes on the bottom plate. Any burn streaks or soil can be removed with wiping the plate with vinegar. After you clean all the holes and slots with vinegar from the outside, TURN ON THE IRON with the vinegar inside. The vinegar will heat up and should come out the holes. If any holes are not blowing vinegar/steam, clean them with q-tips again. Don\'t let all of the vinegar inside steam out!! Just heat it enough to make sure all of the holes are clean. Some white film may come out of the holes on to the face plate--it is calcium build-up from using tap water in the iron.
Now DUMP out vinegar inside the iron and reservoir through the pour-shoot You may see crud and crap coming out. Repeat the process of filling it up, steaming through the holes etc. until the vinegar comes out clear!!!
DON\'T use tap water in any IRON. Use distilled water, or even bottled drinking water (without flavoring, additives, of course). This will prevent corrosion and calcium build up in the iron.
ALWAYS completely drain the iron from the pour-in spout each time you are finished using it!! After pouring out the tank\'s water, you can set the iron to STEAM HIGH, and force any water inside to boil off and out of iron.! Never keep water in the reservoir or iron.
I set my iron, when hot, and done using it, with the pointed side DOWN in the sink drain to make sure it is dry.
So clean it with vinegar often, use bottled drinking water or better, distilled water and it will prevent this.
Oct 24, 2013 | Irons
How do I use the self clean button in the DW5080 Focus 1700 Watt Steam Iron
please read carefully the owner manual and get the information about how to use the steam.
download from www. fitness.manualsonline.com
God bless you
Feb 01, 2013 | Rowenta DW5080 Focus 1700 Watt Steam Iron...
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Aug 04, 2011 | Russell Hobbs 13153 Iron
I have a hinari steam generator iron and the steam has stopped coming through the iron and now coming through the base that the iron stands on!can anyone help please
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks.
Thanks for asking.
Jul 13, 2011 | Rowenta Steam Generator DG050 Iron
Sole plate leaking
This IS a steam iron? The iron must be hot for the steam to form. If it's not hot enough, the water is leaking thru the steam holes. Also if the channels are calsified (boiler stone has formed into the steam channels) this may happen.
Nov 04, 2009 | Tefal Irons
George
Jun 23, 2008 | Oreck Cordless Speed JP8100CA Iron
Irons Logo
Top DeLonghi Irons Experts
Charles T Nevin
Charles T Nevin
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a DeLonghi Iron Expert? Answer questions, earn points and help others
