Question about Bernina Sewing Machines
Bernina 1300 MDC will not stop surging. A new machine, only used a few times. Starts slow then gets faster without touching anything including the petal.
Have re-threaded, tried different thread, cleaned the machine, inserted new needles, check petal..all seems fine, except once tuned on it just goes, the only way to turn it off is to turn the machine off.
    Master:
  • Bernina Master
  • 470 Answers
If it is new, you probably have a Warranty? Take it back. This could be a safety issue.
Posted on Apr 02, 2015
  • Bernina Master
  • 11,774 Answers
Yes, definitely take it back to the Bernina for repair. It sounds like it is defective and should be fixed under warranty.
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
RickE1
  • 202 Answers
SOURCE: Timing for Bernina Virtuosa 153
Timing these machines gets pretty involved such as in just removing the covers. You need a grounding ******** your wrist as the cables all need to be unplugged and you don't want to send a static charge from yourself to the circuit boards. They are expensive. Then you need special sized metal pins to pin several pinning points so the needle, hook, stepping motors and feed dogs all co-ordinate with each other. Also several places need certain guages to set less than .1 millimeter size distances between different places to avoid other problems. You also need several sized torx screwdrivers and the knowledge to adjust the upper and lower tensions. The upper tension alone has at least 3 or four places that need to be in the correct position.
All of the above has to be done in a certain order also.
Its complicated enough. If someone is going to walk you through this over the phone expect it to be complicated. Even if you had a copy of the manual (which could be a copywrite infringment on newer machines) you can expect it to be difficult.
My advice is to leave it to the professionals to have it done right.
Posted on Jun 20, 2008
i_luv_2239
  • 23 Answers
SOURCE: The needle thread will not pick up the bobbin thread
It looks right but its not. Try looking on the internet for threading instructions. The bobbin winds in two directions, I have never saw a Bernina but I have 2 new machines and the thread goes in and then threads back to the left. Its hard to describe. But if the bobbin isn't right it will not pick up the thread. Write to Bernina for instructions. There are websites that have the directions for free.
Posted on Nov 19, 2008
RickE1
  • 202 Answers
SOURCE: BSR skips stitches
Hi, I am a Bernina tech and can tell you what the problem is. The problem is that the spring on your BSR is weak. Bernina has an upgrade to adding a heavier spring that solves this problem. The older lighter springs on the BSR is shiny. The newer heavier updated spring is dark. Ask your dealer/tech to change this spring to a new one or give you a newer updated BSR. Also be sure they updated the BSR to the latest firmware.
Rick
Posted on Oct 08, 2009
Testimonial: "Thanks, this was very helpful!"
  • 86 Answers
SOURCE: the upper thread in the
Wow, what a challenge. There are a lot of reviews/complaints about how temperamental this model is- sewers either love it or hate it and have the same problems you describe. Since I am an experienced sewer and have lots of vintage black Singer models, ( I got rid of the newer models), I wouldn't mess with it any further...If you can, take it to a Singer authorized repair person....they can sort it out for you. Sounds like you've done everything you could so far. Good Luck.
Posted on Jul 23, 2011
My Bernina 1300 MDC serger stopped sewing. The light comes on and the machine makes the start up noise but, when I press the foot pedal, nothing happens.The foot works with other machines.
check to see if any thread is jammed inside the right turning side wheel in the core area at times there can be thread that flies in there and may stop the main belt turning.
Apr 08, 2017 | Bernina Sewing Machines
Bernina 1030 starts by itself and runs very slowly some time after parking the needle at the top
This is most likely a fault in the foot control. Normally supplied with this machine is a Type 10 and this can be fixed quite easily but probably not by the machine's owner unless you have some electrical and mechanical experience.
If you have knowledge of and access to a multimeter, you can test it. What working properly, you will find the following:
Pedal released: resistance is infinite (anything around 4k Ohms or less and the machine will run).
Heel pressed: resistance is about 10k Ohms.
Toe steadily pressed from nothing to all the way down: resistance is infinite then after a small depression, jumps to about 4k Ohms steadily decreasing to zero as the pedal reaches all the way down.
Your problem, being at the point where the pedal isn't pressed suggests that there's some contamination in the pedal. It's also possible that you have a type 365 pedal (as used on the 930) and this is more likely to give this kind of trouble due to the use of carbon brushes in this foot pedal.
Feb 07, 2014 | Bernina Sewing Machines
Bernina artista 180 touch screen slow to respond
I would suggest contacting a sewing machine repair shop
& ask them about the slow response of the screen, & see what they
say & base your decision on that
Aug 07, 2012 | Bernina Artista 180
Bernina 730 locks up, had to turn it off & back on 3 times before it would do anything. I switched it from sewing to embroidery, totally locked. It's been to the shop twice recently.
Typically, ther are two problems with locked up Bernina 730's:
1. Look for a split in the worm gear on the cam stack...(white Delrin systhetic gear attached to the steel cams.
2. Look for a crack in the vertical shaft gear...(Delrin synthetic gear as well)
These gears have given great performance for over 40 years and may need to be replaced...
Sep 05, 2009 | Bernina Sewing Machines
Starting overlocking
hi there,
check & correct the FF:
  • Correct thread tension.
  • Replace needle.
  • Replace needle with correct size.
  • Use proper thread or needle.
  • Check threading order.
  • Increase pressure on presser foot.
  • Reset needle.
Jun 01, 2009 | Bernina Sewing Machines
Model 6010 Won't Stop Sewing
I would say that is the computer in hte machine
Jul 18, 2008 | Husqvarna Viking 1
Dongle
Hello. No, the only way you are going to get this to work is to replace the software with new ones, as all software come with different dongle numbers. The dongle numbers are specifically for the software that you have, you can't even change dongles. Can you get in touch with the seller to give you the dongle? I have a set of Cracked software for the BERNINA ARTISTA 180 that I can copy for you for $200, which you don't need a dongle for. Email me on: lfr6@bigpond.com I have a BERNINA ARTISTA 180 as well and this is the software I run. RRP for the VERSION 3 and the CPS software is $4500.00. Thanks. Lawrence
May 02, 2008 | Bernina Artista 180
Sewing Machines Logo
46 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
