Question about Nokia Cell Phones
Saving contacts to sim with broken screen. nokia 1661-2, please help me out with clear steps, thank you
How to save contacts to sim blind
SOURCE: saving contacts
Check your contacts maybe you enter smae numbers on a 2 different contacts
Posted on May 02, 2008
SOURCE: Contacts... broken screen
aaaa
Posted on Oct 21, 2008
  • 173 Answers
SOURCE: how do i save contacts to sim
N95 does not save contacts to sim automatically. But onnce you have saved a contact to your phone memory, then you can select OPTION and MARK the contact and then OPTION again and select copy to sim. You can do 1 or multiple contact copy to sim. But remember that the sim card holds only 250 numbers
Posted on Jun 05, 2009
SOURCE: my nokia screen is broken and i have saved my
u cant do that.... although u can backup ur messages using pc suite and restore it to ur new phone..
Posted on Jul 17, 2009
  • 96 Answers
SOURCE: change from nokia n95 to new mobile want to save contacts to sim
You'll probably find they're already on the sim, if not here's how to copy them over.
Open contacts, options, SIM contacts, SIM directory; you should see all contacts that are on your sim. If there's none there, select back which will take you to your contacts; choose options again, scroll to mark/unmark press select then mark all, all contacts should now have a tick beside then. Then options again, copy & lastly to sim directory.
Posted on Aug 24, 2009
Need step by step instructions on how to save contacts to sim on a nokia n95 with a broken screen phone still turns on but cant see anything
Hi, as the LCD screen of the Nokia N95 is broken, I suggest that you use Nokia PC Suite to backup the Contacts to the Computer.
Please download the Nokia PC Suite from the below link:
http://www.nokiausa.com/get-support-and-software/software/nokia-pc-suites
Apr 13, 2011 | Nokia N95 Cellular Phone
Tip
Saving contacts to SIM with Broken Screen Nokia 3109 3109c 2323 2323/c and...
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Save Contacts to SIM blind. Nokia Broken Screen
Press Central Navigation Button to get Menu
Press Up once - Contact Menu
Press Central Nav Button
Press Up once - Copy Contacts Menu
Press Central Nav Button - From phone to SIM card
Press Central Nav Button - Confirm copy
Leave for a few minutes depending on how many contacts you have to copy
Press Button above call end several times to exit from the menu
on Aug 06, 2010 | Cell Phones
I lost my securtycode nokia1661
To master reset the phone, perform the following steps: IMPORTANT: A master reset restores the handset to factory settings. This clears all downloaded content, saved images, messages and phone contacts. If any contacts or content are stored on a memory or SIM card, they will not be deleted. 1. Back up all necessary data on the internal memory. 2. From the main screen, select Menu. 3. Scroll to and select Settings. 4. Scroll to and select Restore factory sett. 5. Enter the security code. NOTE: The default password is 12345. 6. Select OK
Dec 18, 2010 | Nokia 1661 Cell Phone
I want to unlock my nokia 1661 from trinidad to work ing st vincent
Please try with this *#7780# , you have to type this code on the main menu, note that it is done without sim card or you'll loose everything saved on the sim card. For more details please check out my tips and tricks page. http://www.fixya.com/support/r4739201-nokia_mobile_phones_security_secret Good luck. Thanks for using FixYa.
May 30, 2010 | Nokia 1661 Cell Phone
I have a nokia 6021 and my screen is broken how do i transfare my numbers from phone to sim
This also maybe useful
Delete Inbox Messages Blind Nokia Broken Screen
Press left once
Press up once - Message Menu
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
http://www.fixya.com/uploads/images/eb5cca9.jpg
May 21, 2010 | Cell Phones
I have 2 nokia phones.... one 5800 and one 1661... i save all my contacts to my SIM card.... the 5800 shows i have 198 contacts... but when i switch phones.... the 1661 shows that i only have 16...
It could be two things, first off make sure you are actually going to the sim card on the 1661, I believe you need to go into the settings of the address book and specify to copy from sim device to phone book, otherwise you will only see contacts stored in the 1661's flash memory.
If you are certain you are viewing the contacts on the device then it is a compatibility issue on the SIM device between the two phones. I recommend you take the two phones along with the SIM in question to your nearest wireless network provider office, they will be able to verify that it is either a compatibility issue, defective sim, or just a simple error in where the contacts are viewed.
This should cover ever possible scenario.
Thank you so very much for the opportunity, this should definitely help you out!
Thanks
Tim
Jul 13, 2009 | Nokia 1661 Cell Phone
Answer to Clarification request
no probs..here is the way,start from the default screen
press the menu(centre button of the 4 way pad)--two down presses on the 4 way pad--centre butto-- again centre button--upper left button--three presses of down button --centre button--centre button again--one click of down button--one click of down-centre button--top left button
that should move all from SIM to Phone
please get back if any help/clarification
Nov 27, 2008 | Nokia 6030 Cellular Phone
Nokia 6030b with broken screen
u better buy a new LCD for ur cellphone. saving data when you can not see the what is writen in the screen will cause more problem.
Nov 25, 2008 | Nokia 6030 Cellular Phone
Broken Dispaly
Install and use Samsung PCStudio 3.2. (download it from samsung mobile web site). You can save everything in your phone to you PC using it software. It is not necesary to see the phone screen to do that. Hope it help.
Aug 19, 2008 | Samsung SGH-T519 Cellular Phone
My old LG cell phone (LGCU400) broke and was replaced with a newer model (LGECU515). I put my old sim card in the new phone but I cannot retrieve any of my contacts/info from the sim card. Is there...
Hello!
I went to the AT&T/Cingular store and they tried hooking my broken phone to their system but could not retrieve any #s (they were saved to my phone not my SIM). They told me there was no other way to retrieve the #s and that a computer cable wouldn't work bc their system would've been able to retrieve them. I knew there had to be some way of retrieving them bc I could still turn my phone on- the top 1/2 (screen) had just broken off.
It finally dawned on me to look at my husband's phone (we had the same one), write down the buttons to press & the # of clicks per button on my old phone, in order to blindly go through my entire contacts list and save each one to my SIM card. Approximately every 25 contacts I saved I'd switch the SIM card to my new phone and make sure they were all saving correctly. I'm currently still transferring all 137 contacts- grueling but well worth it. This only works if your old phone will still turn on & function even if you can't see/use the screen.
***Make sure your phone's saving your contacts to your SIM and not your phone- I thought mine was and it was one rude awakening today when I found out otherwise! I hope this helps!
Apr 22, 2008 | Cell Phones
Cell Phones Logo
56 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
