Question about Emerson Pool & Spa
I am trying to find a replacement basket for a emerson pump model T55CXCLL-1386 Cat EQC1072 HP 3/4
  • Emerson Master
  • 1,631 Answers
Emerson does not make pumps. They produce a motor, as a third-party vendor, and a pump manufacturerer will use their motor.
so, the information you provided, is for the motor, we cannot assist you to locate a basket for your pump, with those numbers. Provide us a make and model of the pump. If you can't, take a picture of it, and upload that.
Some information... Or terminology, that might make things a little more clear:
A motor is the electrical component that is attached to a Wet End.
The Wet End or the Liquid End houses the impeller which is what moves the water when the motor begins to turn.
The two together make a Pump.
The Motor by itself, is not a pump. The wet end, is not a pump by itself. Again, the two together make the pump.
Common names/brands of pumps: WaterWay; Hayward; Pentair; Sta-Rite (now Pentair), Jandy, among others.
Posted on Apr 02, 2015
What size capacitor is in the 9352-9303Emerson spa motor?
Try using the values listed on the one on/in the motor.
Sep 11, 2014 | Pool & Spa
I want to install a larger motor on my emerson model k55myjdh 9025 pond pump any suggestions?
it can be done, you can go up in hp, just not down without changing the impeller. so lets say you have a 1/3 hp now you can replace it with a 1/2 hp . the bigger motor is not going to make a big difference in flow, but the motor will run cooler usually making them last longer.
jay the pool pump motor repair guy in longwood florida .. vote
May 30, 2014 | Pool & Spa
I had a Smith 1HP pool pump with a square flange on my Haywwod sand filter. After 12 years it died. The pool shop sent me home with a Emerson 1hp., 1081 pool motor. It doesn't pull the water like the...
Sounds like there is an impeller problem. A 1hp emerson should be fine. Take it apart and recheck impeller and diffuser. I am assuming they gave you a new seal to replace with the motor.
Apr 26, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
I need a replacement pump and motor for an older Bath Tub Whirlpool The motor is an Emerson 1/2 HP 115 vac (Model # SA55NXKHC-5590) and the wet end Part # is 91040810.
that is an Aqua Flo bath pump model TMCP 1 hp model. that has been replaced by the NEW Mfg with a pump called the WhirlMaster.
You may find that pump at www.uspartscenter.com
Feb 12, 2011 | Home
Where can i order the impeller (center dish cover) for a emerson 1081 3/4 hp pump
The impellers for the motor depends on the actual brand of pump that the motor is actually bolted up to. Impellers are available anywhere and once you can let us know what the actual model of the pump (should be a Hayward, Jandy, or it may be an off brand) we can not only provide you with the part number, but also a location where to purchase. What is probably happening is that you are searching for the impeller for an emerson, instead of looking for the imepller for the appropriate pump.
Feb 07, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Hello, I have an Emerson Spa Pump Motor ( 2 HP, 230v, 3450 rpm). The motor has model R610867, cat 7610, sf 1.3 on it. It also has "1081 motor" on the label. I am tring to find a...
should be a 30, you can have the old one tested it might be good ? I write the value on the back and side for future reference to avoid this problem as the value is normally not stated on the motor's label like is done on air conditioning motors. search your area for your LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING
Jun 03, 2017 | Emerson Pool & Spa
I need to purchase a Emerson 1563 spa motor. Cat. 9352-9303 Model K55MYGRD-8367 hp 1/15 and 230 volts. Can you help me?
This place has them:
http://www.affordablespasandparts.com/Aqua-Flo-CMCP-R0-1-15-hp-230v-1-spd-02593001-2010GK.htm
Jun 27, 2010 | Pool & Spa
Just replaced my Emerson 2hp pool motor. Turned on new motor all is working fine but water isn't filling the basket?
First of all you need to fill the pot with water. it is best to pour a bucket in or use a hose and turn the pump on and off real quick a couple times to **** some water into the pump. Once you do that fill the basket as much as possible and quickly put the lid on and turn on (make sure your lid o-ring is there and in good shape. lubricate it with pool lube so it's wet but not all gooped up). when you turn the pump on you should see water either splash, or at least start trickling into the pot. if you see water splash in, but then go dry again, or if it just trickles but doesn't prime after about 20 or 30 seconds, then you may very likely have an air leak on the suction side. Make sure your lid is sealed, the pipe goin into pump is not loose or leaking air, and make sure the pool cleaner hose is not out of the water, or the skimmer sucking air. If the pipe coming into the pump is sucking air or you suspect it might be try wrapping black electrical tape tightly all around the joint (where it threads into the pump). This is temporary troubleshooting step but works great. If there is a union or a Jandy valve where the pipe comes into the pump check o-rings and all joints for leaks.
Jun 23, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
May 25, 2009 | Jandy PHP High Head Pump 2 HP Up rated
Pool & Spa Logo
76 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
