Question about Sunbeam Irons
Cord stop working can it be fixed - Sunbeam Irons
My iron just stopped working,there is no power.
Could be heating element or power cord, if needing more assistance let me know...easy fix if you know electronics
Feb 28, 2014 | Rowenta DX6700 Iron
Iron heating sporadically and sensor lights working sporadically
It looks like the cord has a loose connection and will need to be replace.
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
It is my first time using it, I brought it from USA and it is not working at all!!
follow this steps and fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electric cord and check the thermostat .
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jun 11, 2013 | Black & Decker Irons
How to stop a flat iron from turning on and off when being used
sounds like a bad connection in the power lead be careful about a possible short hazard ZAP!!! Find a handyman to fix it.
May 16, 2013 | Sedu Pro Ionic Ceramic Tourmaline Flat...
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
I GET NO HEAT IT JUST STOPPED
U got a busted thermal fuse or the thermostat switch is not functioning.
If u have a knowhow in replacing and adjusting the thermal switch, u could fix it by urself!
Better check also the power cord, mostly flat irons main prob, if there are no lights on ur iron, it means internal probs!
Better take that iron in ur friendly hungry technician to fix that!
Dec 02, 2010 | Rowenta Professional DE880 Iron
I have two irons. one if them won't turn on anymore and i noticed the light kept fading out. the light on the other one flickers and it stops working halfway through straightening. any solutions?
Most likely it is the power cord. We have the same iron and the power cord has a break in it just as it comes out of the swivel. You can turn it on and hold the power cord tight up against the swivel and it should stay on. I was able to fix it by stripping the cord down to the wire soldering and adding shrink tubing to the connection. That lasted for about 1 year and it has done it again. I may have to replace it but not sure how to take it apart.
Sep 19, 2010 | Conair Infiniti Instant Heat Ceramic Hair...
My polti 750w mod PRO VT doesn't produce steam
i woundnt see why not alls that needs to be done is replace the power cord to the unit your local electrician store should be able to fix that
Apr 21, 2010 | Irons
T-fal ultra glide easy cord iron stopped working while ironing
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 03, 2009 | Tefal UltraGlide 1569 Iron
Turns on, flashes yellow but never heats up
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jan 12, 2009 | Rowenta Effective DX1900 Iron with Auto...
Irons Logo
131 people viewed this question
Top Sunbeam Irons Experts
Tony
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
