Question about Electrical Supplies
How do you reset the circuit breaker? - Electrical Supplies
    Problem Solver:
  • 17 Answers
When a circuit "pops" you must turn it off then back on if it sparks and pops off again do not try a third time. means its is shorting out.
Posted on Apr 02, 2015
If the circuit breaker as tripped ,how do I get it to untripp it
If the fault that caused the breaker to trip still exists, it will not reset. Unplug any devices from the circuit in question and reset the breaker. Then plug in items one at a time until you find the device that is causing the breaker to trip. Then fix or replace. You may also have a bad breaker that needs to be replaced if it will not reset even with all devices off the circuit.
Feb 08, 2016 | Electrical Supplies
How do I know if the 50 amp manual reset circuit breaker needs to be reset? there is a small yellow lever with reset printed on the top
If the breaker handle is in the middle position, it needs to be reset. you reset it by pushing it to the OFF position and then to the ON position
Oct 29, 2014 | Bryant 50 Amp 2 Pole Br250 Type Br Ni...
LAst night we lost two rooms completely light and outlets. we try the reset the breaker nothing would come on. This morning we unplug everything turned on the breaker, and plug everything back in...
1) A circuit breaker will not reset if breaker is hot, or if there is a short to ground.
2) Hot breaker: If circuit is pulling more amps than the breaker rating, or if breaker is loose on the busbar, then breaker gets hot, and trips.
3) Volts x amps = watts. Add up wattage of everything on breaker and divide by 120Volts and that gives you amps.
If your breaker is 15 amps, the SAFE maximum is 80% or 12 amps.
4) If breaker is loose, you can smell burning and hear crackling sound. Jiggle the breaker around and listen for crackling.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
5) If there was a short somewhere on the breaker circuit, the breaker will trip.
When you unpluged each device and then the breaker was reset, then that says problem is probably NOT the wiring or breaker.
The problem was probably inside one of the devices that was plugged in.
6) If breaker trips again, unplug each device one at a time, and then try to reset breaker after each unplug to see if you can isolate suspected device.
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 29, 2010 | General Electric 20 Amp, 1 Pole Thick Type...
How do I reset a Eaton breaker with a tester on it?
This is a GFI (Ground Circuit Interrupter) Breaker. So you need to turn off the circuit breaker first. Then you need to reset the GFI (yellow button) by pressing in the button. And then turning the breaker back on. Now, with some GFI's, you need power on to reset them. So if this is the case, reset the circuit breaker by turning it off and then back on. Then press the yellow button in, and it should hold. Then you should have power restored. I hope this works for you. If not, feel free to contact me again. Good Luck!
Mar 27, 2010 | Eaton 20A ARC FAULT BREAKER
Breaker wont push back in
it is still detecting an overload in the circuit. Take the black wire off the breaker and see if it will reset. If so then you will have to trace the wires down to find the short circuit. If it doesn't reset then the breaker is bad
Jan 25, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
Bathtub pump totally dead, pump ran dry for 10 sec, is there circuit breakers on pump motors, switch or is it the motor shot. any way to test motor with removing it?
Normally pump motors are connected on a separate
circuit with its own circuit breaker. At your house there is always a electrical control panel housing several circuit breakers for lights, power outlets, range, aircon, motors, etc...Find a tripped off breaker and reset it. To reset the circuit breaker is to switch it to off position and back to on position. Better still you may reset all the circuit breakers except the main
circuit breaker (biggest amp rating).
After resetting the circuit breakers, try to switch your
bathtub pump on, (to test it, if it is still okey). Other-
wise, your motor is damaged and you got to have the
motor rewinded, to be operational.
Dec 09, 2009 | Plumbing
I have 2 siemens circuit breakers that won't reset. How can I do
unplug the appliance that is overloading the breaker.
reset the breaker, plug in the appliance. if the breakers pops, then the appliance is the problem.
you may want to check the appliace manual and make sure the breaker is rated for the appliance you are using.
Dec 25, 2008 | Siemens 2 single pole 15 amp breaker
Electrical Supplies Logo
374 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
