Question about Toshiba 40RV52U TV
ToshibaModel toshiba 40rv52u goes on and off
Set goes on and off by itself was there a recall on this model the capacitors look ok no leaks and also is there a 808 .2uf capacitor in this model cannot find if there is a reviewer stated it could be the problem? Would a new power board possibly correct the on off? Thanks for any feedback
    Top Expert:
  • Toshiba Master
  • 74,211 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 02, 2015
  • 60 Answers
Dear User,
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator section circuit. Contact any service technician.More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Faisal
Toshiba 40RV52U TV has just started cycling off & on. Is this a problem with the power board?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 20, 2016 | Toshiba 40RV52U TV
Toshiba 37X3030D TV. Screen fails to light, sound OK.
That'll be the inverter board. It might be the 6632L-0490A made by LG Philips. If it is, you'll find the 2 capacitors have leaked and a bit has blown out of the chip. The inverter board is hidden behind the main board on the 505 model.
Mar 27, 2014 | Toshiba 37X3030D 37 in. LCD TV/HD Combo
Toshiba 40rv52u remote control
If just using one remote to try have it tested----many digital cameras in a dim light will react with a flash on the display screen when remote is pointed at them and buttons pressed.
Also try putting remote against remote receiver lens on front of set--if it reacts close up---the remote receiver in the set is bad---can be same if no reaction at all.
Either the remote or the receiver---one or the other.
A last thought here is some sets (read owner manual) have a feature to lock out the remote which can be engaged by accident.
May 15, 2012 | Toshiba 40RV52U TV
My toshibamodel 32AX60 has no picture screen is black just a voice
The horizontal output section circuit should be checked for fault.
Apr 29, 2012 | Toshiba Televison & Video
Intermient fault. The set comes on and goes off . Tried few capacitors and dried joing but no joy. can u plz help me? Thanks
Normally faulty capacitors are the culprit for this issue. Make sure all bulging or leaking capacitors are replaced. Check also for loose connections or burned parts or parts that have a burned smell while the power is not connected. It could also be a software issue, your sleep timer may not be working but this can be rare. You may want to play with this to test.
It may be the power supply circuit itself that needs replacing. Other parts when faulty may still allow the TV to run. Faulty parts that would let the entire unit over heat or burn out would trigger the shut down.
Apr 04, 2011 | Televison & Video
There's 4 horizontal white tiny lines appear on screen to make the picture become 4 equal parts from top to bottom with many horizontal lines. My TV is Toshiba Lcd(40RV52U)
You have failure/weakening in the vertical section , the retrace lines appear due to the change in the freq.
Check out small value capacitors in this section. confirm by shorting parallel with the right polarity. Unless you are familiar with electronics please do not attempt unless with help. the fault is not very serious and could be attended with low expense.
Jun 30, 2010 | Televison & Video
My toshiba problem.
You may have bad T-CON board, try cooling it with small fan blowing on the vents of the TV.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 30, 2010 | Toshiba 40RV525U 40 in. LCD TV
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
Toshiba 40RV52U TV Logo
71 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
