Question about Homelite Garden
Homelite UT-08544 fuel line which one goes to bulb which one goes to carb
  • Homelite Master
  • 1,169 Answers
I wish those posting answers could get things right.
The remote primer does not push fuel into the carburetor; it for pulling fuel mix through carburetor removing air line the system.
Here is the basic setup for a remote primer.
Homelite UT-08544 fuel line which one goes to bulb - 25622627-0wu205ooc1s2ktaogfiiniys-1-0.png
Posted on Apr 02, 2015
  • Ted Maxwell Apr 02, 2015
    Way to go Eugene! Your diagram is great and I stand corrected,
  • Homelite Master
  • 3,519 Answers
Hi Clark:
The fuel line goes from the fuel tank to the bulb, then another line goes from the bulb to the carb. So, it is from the gas tank to the carb, with the bulb in the middle. Pushing on the bulb should make gas squirt into the carb so you'll know you have it connected properly.
  • Eugene Rounds Apr 02, 2015
    Ted, You are mis-informed on how the 2 cycle primer systems work.
#1 Taper
  • 1040 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • 3600 Answers
SOURCE: the primer bulb does not draw fuel thru carb
you need to buy a primer bulb kit and replace it cost about $8.00 and is easy to put in, the check valve is damaged.
Posted on Jul 18, 2009
  • 52 Answers
SOURCE: is the primer bulb suppose to have gas in it this is a homelite
Here's a sketch that might help you. The primer bulb will keep fuel in it. 3985d0d.jpg
Posted on May 02, 2010
panilling9
  • 284 Answers
SOURCE: Which fuel line "port/inlet" on the Walbro wt-380
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Posted on Jun 25, 2010
hunter19_46m
  • 7482 Answers
SOURCE: diagram for fuel lines on 25cc homelite ut20811b gas trimmer
Hi martinez7568
I believe the picture below is what you are looking for.
Please take time to rate me
Bud
Posted on Oct 25, 2012
Homelite ut-08068-r leaf blower leaking fuel
If we are talking about a hand held leaf blower. The fuel leaking from the carb is likely caused by a stiff metering diaghram holding the needle open. Rebuild your carb ( I suggest also replacing the fuel lines and primer bulb while you are at it) and double check the lever adjustment.
Oct 23, 2012 | Homelite Garden
Craftsman 33cc weedwacker rep lace fuel lines
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Feb 21, 2012 | Craftsman Garden
Fuel line diagram for sears mini cultivator
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Feb 17, 2012 | Ryobi Garden
Internal line in gas tank came loose
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
Jan 18, 2012 | Garden
Fuel line routing for craftsman chainsaw 358.350370
Jan 11, 2012 | Garden
Craftman trimmers has two gas lines wich one goes to the primmer the one with the filter or the thine one
Jan 09, 2012 | Garden
My Homelite Vac Attack II is 4 years old and I
fit new pump ad float diaphragms in the carby
the fuel mix has become irrelevant as Stihl have an oil that is a 50:1 oil and covers all ratios and mixtures
do not use any e-mix fuels as that destroys carby components
Aug 09, 2017 | Homelite Leaf Vac Attack
Fuel line on Homelight
the filter in the gas tank that line goes to carb
and the one that line goes to bulb
Jul 18, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
On a homelite chainsaw model d3300 i have all fuel lines lose and have forgotten location of where they go. What is the locations of the supply lines from the gas tank to the carburator?
The line that hooks up at the front of the carb (#17 in picture) goes to the fuel tank. the line that hooks up at the rear of the carb (#18 in picture) goes to the primer bulb. Hope this all helps. Let me know. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chcp%5cimages%5c06%5c01%5c13%5c0007.tif&ilsc=12&iliv=0&ilbr=0&ilif=p&ilre=8
Feb 23, 2009 | Homelite Garden
Garden Logo
921 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
