My pc has a power but i dont have image on my monitorcomponents..?is it ok if i permanently remove the tv component..
My pc desktop has a power but no image in monitor.. it runs but i removed the TV panel..can i use my monitor even i remove the tv
    Top Expert:
  • Computers & ... Master
  • 4,910 Answers
You should be able to.
Posted on Apr 05, 2015
Power supply gt 5404 -iwant to replace 300w psu with more watts, will any atx psu work?
ATX is a sizer variation between Chaises/Cases and Mother boards.
When upgrading a power supply its quite simple. The only hard part is making sure your buying a power supply with enough wattage to supply enough power to your components. With that said Some power supplies are Modular. Which means that you dont have all that mess and you can remove the cables that you dont need, and others are built in. So i advise you to just make sure you have enough wattage to supply enough power to your components. All/most PSU's fit unless you get some custom/fancy rigged one.
Oct 05, 2013 | Gateway GT5404 PC Desktop
Power led light is a steady orange but pc will not power up
If the power light is blinking amber, the computer is receiving electrical
power, a device might be malfunctioning or incorrectly installed.
- Remove and then reinstall the memory modules (see "Memory" on
page 112).
- Remove and then reinstall any cards (see "Cards" on page 116).
- Remove and then reinstall the graphics card, if applicable (see "Cards"
on page 116).
• If the power light is steady amber, there may be a power problem or an
internal device malfunction.
- Ensure that all power cables are securely connected to the system
board (see "System Board Components" on page 107).
- Ensure that the main power cable and front panel cable are securely
connected to the system board (see "System Board Components"
Copy and paste this link to your internet browser for your computer's manual.
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_inspiron_desktop/inspiron-531s_owner%27s%20manual_en-us.pdf
You can also go to support.dell.com
Jan 08, 2013 | Dell Dimension 4600 PC Desktop
IF THE LIGHT ON THE MOTHERBOARD IS LIT, IS IT OK TO REMOVE OR REPLACE COMPONENTS?
Before you should remove anything from inside a pc turn off the power supply which will resolve the light issue as well .. to be on safe side i would say no.
Jun 06, 2012 | Dell Computers & Internet
My DYNEX 19" LCD TV dont turn on?
Power at the outlet? ok?
Plugged in the outlet? ok?
Power cord plugged in to the REAR of the tv very snug? ok?
Using the remote? Batteries ok? ok?
Red light on? ok---- Unplug the tv for a few seconds and retry. ok? Still no-go?
Unplug the tv and remove the rear cover, remove the stand screws to do this. ok?
The small circuit board ( you will be certain you have the correct board simply because it is the smaller of the two boards. The Mother board is much larger. Another way to be sure you have the correct board is to folow where the power cord connects to the tv----that board!!! )ok?
Now, very important!
There are small components called CAPACITORS. They are approx. 1/2 inch high and about the size of your pinky finger around. They all look about the same, but vary in size. They will have an "X" marked on the top usually. Now, this is what to look for! They must be FLAT on top. If they are round, buldging, or burnt then they are BAD!!! Take care and you can easily remove the board by simply removing the wires and screws from the board. (be sure to draw on paper where things go or otherwise mark where they go so reinstalling the board will be rather easy)
Remove any glue from them carefully and then using a soldering iron or gun just simply melt the solder on the rear of the board and pull them out. Take them with you to your local electric supply store and solder in the new ones. Look for any bad ones on the MOTHER board also and replace if needed. Rarely are they bad. The problem is nearly always with the POWER board.
With everything hooked back up and put back together, plug the tv in to the outlet and turn on the tv. Voila, enjoy!
NOT willing to do this. Well, simply get the model number, etc., and google the power supply for it and order it. Install it, trust me you CAN do this, and There you go. Enjoy!!!
Mar 24, 2011 | Dynex DX-LCD19-09 19 in. LCD TV
Power but no display acer aspire L100
Try these sequence(you need another one good computer to test and interchange component and you will find out the problem):
- check your RAM, if you use two RAM start computer using one and interchange it to find out which one is bad
- if your RAM OK, check your VGA
- if your RAM and VGA OK, try to check your power supply, sometimes defective PS cannot supply sufficient power to all component to work.
hope this will help you.
Jun 07, 2009 | Acer Aspire L100 PC Desktop
ACER Veriton 5600GT how to turn off USB power after shutdown
Not likely.
What you have is power over USB which is good because it allows the hard drive to get enough power to run without a seperate power cord. This is also usefull for IPODS and other media that Charge through a USB. It means you can turn your computer off and still charge something.
If its an external hard drive, its meant to be removed. You can right click and disconnect it from the bottom right and then remove it safely.
You may have a port that doesnt provide power when turned off, maybe a front USB port, you could plug it in there.
There most likely isnt a way to change any jumpers unless your system board instructions specify that you can and how to. Dont go tinkering around because if you put jumpers on the wrong spot, you can blow some of the small components on the board.
This would render the USB completely useless.
If you want a permanent extar HDD for back up, just get a new IDE for the internal, There cheep these days. you can get a 250 gig IDE for under $60.00
Feb 03, 2009 | Acer Veriton 5600G PC Desktop
Image lost after 5 min turning on the tv, sound was ok.
I would suspect overheating of an electric component in the power supply of the lamp (backlight) of your lcd tv. bring it in for repairs.
Nov 29, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
I have malware and trojon infections. desktop icons that have appeared and cant be removed permanently and computer is running very slow. please can you help me to resolve the problem as i dont have...
ok
install free avast antivirus then update it with internet.
then u see boot time scanning option.
then if u found any virus delete it witjhpressing "1" key.
Nov 09, 2008 | Siemens Computers & Internet
Gateway PC
the front cover first and the side cover needs to come off and then there should be screws behind the fromt cover that are holding in the power switch in place then remove all of the wires and please please dont forget where they go then remove the switch from the computer i would put the screws back into the computer so u dont loose them ok untill you are ready to put in the new switch i hope this is really heapfull for you keep me posted ok i am here to help best regards mike
Jul 08, 2008 | Gateway GT5220 PC Desktop
Computer will not power at home ok at friend home
ether the power supply is bad or your outlet is not grounded
Mar 27, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
