Question about Husqvarna Garden
Tried to replace my chainsaw on my husqvarna 445, but the brake seems to have not released, so I can't get it back together
  • Husqvarna Master
  • 1,169 Answers
Not an easy thing to reset either. You can try putting chain brake back on with the retaining nut(s) loose so don't go flying. Now place the reset handle as far forward it will go. While pressing hard with hand at the chain reset location of the cover pull back on the reset handle. This should reset the brake.
Note this will not always work and sometimes you need a saw shop to help reset it.
Posted on Apr 02, 2015
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
My Husqvarna starts but won't accelerate when you pull the trigger, acts like the brake is on but the handle is in the free position.
It may be running very rich, make sure the air filter is clean, if ok. check the spark arrestor in the muffler outlet ( if fitted ) has not carboned up, if ok, check the exhaust port is not blocked with carbon.
Dec 30, 2012 | Husqvarna 445 18" 45.7 Cc Chainsaw...
Have tried everything but cover will not go back on the husqvarna 445. there is just not enough clearance for the band to go back onto the drum. have tried even adjusting the band tension but that...
The problem you are experiencing is very common. Many people remove the side cover with the chain brake applied or either the brake becomes engaged after the cover has been removed. You will need to reset the brake before you can install it. This is a little tricky but can be accomplished. I find that it is done fairly easy by carefully clamping the side cover in a vise, and using a good strong pair of needle nose, span the "rotator" (star shaped wheel) on the brake and with another pair of pliers, grab the needle nose pliers and "twist" the brake into the disengaged position. Hope this is explained well enough to get the job done.
Mar 04, 2011 | Husqvarna Chainsaw Piston Kit for 61...
I HAVE A 235 16"
A Husky 445 has a compression release (about the same bar length) which gets around this difficulty. We have a 435 Husky that has the same problem--your arm needs to be in pretty good shape to pull them through. We have found that the saw needs only one pull with the choke full on to be able to start on the second or third pull. Back the choke off about half to make the following pulls. Other than replace the saw, not much help I'm afraid.
Nov 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Trying to fit bar and chain on a new 445.can not replace clutch cover after following instructions closely.it seems brake is on. WOULD REALLY APPRECIATE HELP. THANKS.
You'll definitely have to unlock the chain brake to get the cover back on. You should be able to unlock it by pushing the chain brake handle forward, toward the bar and chain when mounted on the saw.
Oct 20, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Have husq 445 removed clutch cover to install bar and chain brake not disengaged cannot replace cover. How to disengage with cover off to reassemble?
Use a heavy, wide blade, square-shanked screwdriver to turn the coupling in the cover to 'release'. You may need an open end wrench on the screwdriver shaft to get enough torque to turn the brake coupling. Hope this helps!
Oct 17, 2010 | Husqvarna Garden
Model 445 chainsaw. Was cutting all day and no problem. Good gasoline, Husqvarna 2 cycle oil. All of a sudden started racing like the carb was stuck full open even when throttle trigger released. Then...
Engine speeding up on idle is normally due to an air leak, check the carb securing screws are tight, if you have a leaking crank seal it will be a shop repair.
Feb 28, 2010 | Husqvarna Forest & Garden #966906636 445...
How to release brake band when cover is removed on model 445 ?
HI. I HAVE USED THEM SAWS FOR 25 YEARS. WELL IT SOUNDS LIKE THE BRAKE IS INGAGED IF NOT YOU WELL HAVE TO LOSEN THE BRAKE OFF UNTIL IT WILL GO ON.WATCH OUT FOR DIRT IN BACK OF BAND. LET ME KNOW.
Aug 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
93 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
