Question about MULTISTAR MULTI MBG30S900SHS BUILT-IN MICROWAVE OVEN FOR 220 VOLTS
Where can you get spare parts for MBGS900SHS
THe black plastic door release has warped from heat
Door release buton does not open the door
You can disassemble the microwave oven and check out the release mechanism. You'll find several hooks that hold the door closed and a linkage mechanism to the door opening button. There may be a broken piece of plastic or maybe just a loose or missing screw that holds linkage together. In the case of a broken plastic part, you can fix it with a 2-part epoxy adhesive, but you'll need to permanently splint across the break with a piece of metal or strong plastic that you've scavenged from somewhere. Before epoxying the splint in place, rough up all plastic surfaces where you want the epoxy to stick well.
Good luck.
Mar 16, 2015 | Panasonic Microwave Ovens
Door release button does not work
busted plastic part in microwave send model # we can find the part you need
Feb 20, 2015 | Panasonic NN-SD277WR - NN-SD277WR...
DOOR LATCH PROBLEM...HOLDING IT CLOSED AND TURNING IT ON WORKS AND HEATS. IS IT A DIY FIX PROBLEM? THANKS FOR THE HELP, DEBBIE
follow this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2gPqmd5pf
Sep 30, 2013 | Frigidaire FGMV174K Microwave Oven
HF24534 plastic door lock broken
same problem here - could not find spare anywhere. have you managed to repair pls. thanks for your help
Nov 17, 2012 | Siemens HF24534 900 Watts Microwave Oven
Hi, the button to open the door not working properly, I am able to press the button in but it is not releasing the door. what should we do?
This sounds like the door release may have broken (duh!) It may be that a peice of plastic has broken or maybe a spring has come off.
It may be an idea to have a quick look inside the microwave to see if you can see any broken parts near the door release... in some cases it is possible to re-glue broken plastic. Do not use super glue as this will not hold plastics properly, you need "evo stik - hard plastic adhesive" for this job.
BE VERY CAREFULL WHEN GOING INSIDE YOUR MICROWAVE! not only does it contain lethal voltages (even when turned off and unplugged), but if you do not put it back together properly you could have microwave leakage which is not good.
Given the prices of microwaves these days it may be nearly as cheap to buy a new one as pay a microwave expert to fix yours.
Mar 06, 2011 | Microwave Ovens
The micro wave door is warped so that the top right latch will not fully engage. How do I fix it?
If the door is warped, buy a new microwave but that is very unlikely.
Release the lower hinge screws and square the door up to the latches then tighten the fixing screws.
Hope that helps.
Jan 12, 2011 | LG LMV1630ST Microwave Oven
Hi, I'm looking for the right cover for a sharp R-1501. It covers the 4 buttons on the right and is plastic. I'm also looking for the door button and spring. These are white in color. Thanks.
A lot of times these would warp from heat.
All of those parts once came as an assembly, which was formerly part number FPNLCB373MRK0 and then FPNLCB431MRK0 ("zero" on the end, not "oh") but both are now no longer available from suppliers.
If you think you can get by with just a door open button and spring, the part numbers for them are JBTN-B143MRF0A and MSPRTA050WRE0, respectively.
You can order them from Encompass here or you can call them toll-free at 866-779-5835.
Otherwise, the oven would have to be retired.
We're happy to help you with free advice and (hoping you don't kill the messenger) we'd appreciate your thoughtful rating of our answer.
Sep 26, 2009 | Sharp R-1502 Microwave Oven
Door will not open. Button release does not release the door latches.
The plastic lever release is more than likely broken. You can order the part from
http://www.repairclinic.com/Appliance-Parts?s=t-KCMS145JSS0-%3d%3dc226g5
It's about twenty dollars.
May 22, 2009 | KitchenAid KCMS145J Microwave Oven
Panasonic microwave door is stuck. The door is not opening
If you push in on the open door button and it just goes in and does not open the door, then the problem is that the plastic piece that actually opens the door has broken. You can verify this by removing the cover from the microwave and look inside. If you are handy just buy the part from the panasonic parts store in your city and replace it. If not take it in and they will replace it for you.
Good luck
Tom
Jun 12, 2008 | Panasonic Microwave Ovens
Removing the microwave door
In many cases, microwave door panels are held together by hidden hooks or catches that ave to be separated by a thin, strong tool such as a putty knife. I've attached a photo that should serve as a good example.
Apr 16, 2007 | Neff H7871A2GB 800 Watts Convection /...
MULTISTAR MULTI MBG30S900SHS BUILT-IN MICROWAVE OVEN FOR 220 VOLTS Logo
35 people viewed this question
Top MULTISTAR Microwave Ovens Experts
William Miller
William Miller
Are you a MULTISTAR Microwave Oven Expert? Answer questions, earn points and help others
