Question about Electronics - Others
Only beep and has no output 120 volts - Electronics - Others
    New Friend:
  • 18 Answers
Burnt out capacitor , or push reset button. Seriously
Posted on Apr 02, 2015
Can I use a inverter for boost for a car amp?
Yeah, it can be done. Instead of the booster being 12 volt, you'll be using a 120 volt booster. Won't make a difference on output of booster, 4 amp and up, whether it's 12 volt or 120 volt power input, you'll just be using more power from your car battery. Be sure you've a good charging system.
Nov 11, 2014 | Car Audio & Video
I have an Astec DS 1500-3-001 power supply that I want to use a a stand alone PS. What pins do I need to connect to get +12v DC output with 120 VAC Input.
Mike
I take it that this is a standard power supply out of a PC (switch mode)
These are a common connection point on any brand PC
Use a DC Voltmeter to find the Ground, +5 Volt & +12 volt wires to power your 3.5 inch Hard Drive. The 2.5" Hard Drives (laptop) has only Ground (Black) & +5 Volt.
Oct 30, 2014 | Computers & Internet
Will there be interference if I hook a Jensen MDV6115 to a 120 volt tv?
Under no circumstances must you use a different voltage ! The power supply on these units are designed for 12v only.
However, if your question is simply referring to connecting the AV 'outputs' (i.e. yellow, red, white rca's) of your Jensen, to the AV 'inputs' of our TV, then that is fine. The AV outputs can be treated the same as any other video device.
Feb 07, 2013 | Jensen MDV6115
Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
Aug 20, 2012 | Behringer EUROPOWER EP2500 Amplifier
NO AC fault
First check your 120 volt outlet.
Then get or test your transformer, 120 volts input, 24 volts ac output.
Connect and you should be good.
Gary
Sep 18, 2011 | Orbit Sprinkler System Power Source...
What are the specs on the charge is it a ac output or is it a dc output
the charger for the battery is 120 volts AC in and the output is around 13.2 to 14.4 volts DC.
hope this is the answer that you were looking for.
c...
Jan 20, 2011 | Black & Decker Drills
On the outlets it has 4/120volts outlets and 1/120-240volts outlet. Can you use the 120/240 outlet as a reg 120volt? And what is the reason of the 120/240 outlet. Thank you
The reason for the 120/240 volt outlet is to be able to run things like large electric heaters or even your clothes dryer as they all require 240 volts. If you use it as 240 volts you will not have maximum current output on your other outlets so you wouldn't be able to plug anything really big in. And yes you can only use is as a 120V output if you would like but you will need a special attachment or extension cord. I'm going to leave you with two reference pages I looked up that you should have a look at.
http://www.powermate.com/generators/product_detail.php?model=PM0435003&cat_id=3&w=59
http://www.powermate.com/accessories/product_detail.php?cat_id=9&model=PA0650192
May 24, 2010 | Coleman Powermate Premium Plus 6250W...
I just baught a used rechargeable lantern, and
What is the Name Brand of lantern you have?
Feb 20, 2010 | Camping, Backpacking & Hiking
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
Electronics - Others Logo
434 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
