Question about Electronics - Others
Turns on but just peeps no 120 volt output - Electronics - Others
  • Charles James
    Charles James Apr 02, 2015
    No power light ,no cooling fan does not turn on, check 12 input is 12.6 to 13.4 new battery's 6 volt wet deep cycle golf cart battery's new wires on every thing all connections tight ,nothing loose?
  • 10 Answers
SOURCE: voltage output is only 50 volts instead of 120 volts
More than likely your voltage regulator is out. The generator produces electricity, so you know the rotor and stator are OK. The 50 volts comes from the magnets permanent properties. The reason you are not getting 120 is because rotor or electron magnet is not getting any power supplied to it, which it needs to produce the amount of electrons you need to have 120vac. Make sure your engine is running at 60 hz first, and you should ohm out the windings and circuits that connect to your regulator.
Posted on Feb 05, 2009
joboo1
  • 257 Answers
SOURCE: Generator output
Hi, You don't say whether this is under load or not but if not is within the acceptable range, which is +/- 10% . Generally speaking, voltage on a generator is not the issue but the load which it will carry, hence their wattage ratings. Measure your household voltage and you will see that it varies from day to day but usually stays within the limits and your electrical panel is rated in amperage. Hope this answers your question!
Posted on Feb 08, 2009
SOURCE: Hi output from generator
I found out that the gasoline motor was turning too fast so I had to turn down the speed of the motor with the adjustment screw.
Posted on Sep 07, 2009
  • 37 Answers
SOURCE: 5250 running watts output on 220 side is 300
I can't tell you what type of rotor excitation you have without the model number but,
If its capacitor excited then you have a bad capacitor(s). If it has a voltage regulator then it could be bad or the sensing wires going to it are bad. If the unit is not sensing proper voltage its going to increase excitation thus causing your units voltage to be to high.
Posted on Nov 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: my 2000 Fleetwood Discovery Motorhome
Terry this unit has 2 AC outputs so the reading that you got is correct. I am trying to surmise the actual problem that you have. You may have lost a system ground in the mobile home which would give you power as you stated but no power to the mobile home as the system ground has been lost.
Dumb questions time.
1. Battery voltage above 10 Volts?
2. Have you checked the DC Fuse?
3. Have you reset the breaker on the control panel?
Last test.. is to disconnect all outputs and try a voltage test again. A system distribution short will cause the inverter to go into the self protect mode.
Kelly
Posted on Aug 25, 2010
Honda ex5500 generator over voltage output
adjust the rpm back to 115-120 volts
or increase voltage to 220-245 volts
Nov 25, 2017 | Honda Electrical Supplies
H ow to replace timer with phot0 cell
Malibu ML300 has 120 volt input and 12 volt AC output
They make a photo eye for the timer... wiring is changed a bit... will work on ML300 if timer has A-B-C wiring terminals
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire
You can use a 120 -> 12 volt ac transformer that is rated for 300 watts... and connect in-line photoeye on the 120 volt side.
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
http://waterheatertimer.org/Reverse-photo-eye-so-it-turns-on-at-daytime.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 17, 2015 | Malibu ML300RTW - Low Voltage Power Pack...
Can I use a inverter for boost for a car amp?
Yeah, it can be done. Instead of the booster being 12 volt, you'll be using a 120 volt booster. Won't make a difference on output of booster, 4 amp and up, whether it's 12 volt or 120 volt power input, you'll just be using more power from your car battery. Be sure you've a good charging system.
Nov 11, 2014 | Car Audio & Video
Will there be interference if I hook a Jensen MDV6115 to a 120 volt tv?
Under no circumstances must you use a different voltage ! The power supply on these units are designed for 12v only.
However, if your question is simply referring to connecting the AV 'outputs' (i.e. yellow, red, white rca's) of your Jensen, to the AV 'inputs' of our TV, then that is fine. The AV outputs can be treated the same as any other video device.
Feb 07, 2013 | Jensen MDV6115
Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
Aug 20, 2012 | Behringer EUROPOWER EP2500 Amplifier
NO AC fault
First check your 120 volt outlet.
Then get or test your transformer, 120 volts input, 24 volts ac output.
Connect and you should be good.
Gary
Sep 18, 2011 | Orbit Sprinkler System Power Source...
My Intermatic T103 Indoor 120-Volt 40-amp timer emits a constant peeping sound
Intermatic T103 is mechanical timer with moving gears.
Timer makes audible sound when tripper clicks on-off, but it should not make constant noise unless gears are causing noise.
Turn off power and spray WD-40 on gears and see if problem continues.
WD-40 vapor is extremely flammable hydrocarbon when sprayed, and should not be sprayed on live electric circuits.
If problem continues, turn off power, pull mechanism out and spray WD-40 on plastic gears of clock motor.
Open following links for illustrations of clock motor and removing mechanism.
http://waterheatertimer.org/images/WH40-005-gears-350.jpg
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Aug 12, 2011 | Intermatic T103 Indoor 120-Volt 40-amp...
Input of 120 volts to fit an inverter
An inverter turns 12 volts into 120 volts. A converter turns 120 volts into 12 volts.
Mar 05, 2011 | Computers & Internet
On the outlets it has 4/120volts outlets and 1/120-240volts outlet. Can you use the 120/240 outlet as a reg 120volt? And what is the reason of the 120/240 outlet. Thank you
The reason for the 120/240 volt outlet is to be able to run things like large electric heaters or even your clothes dryer as they all require 240 volts. If you use it as 240 volts you will not have maximum current output on your other outlets so you wouldn't be able to plug anything really big in. And yes you can only use is as a 120V output if you would like but you will need a special attachment or extension cord. I'm going to leave you with two reference pages I looked up that you should have a look at.
http://www.powermate.com/generators/product_detail.php?model=PM0435003&cat_id=3&w=59
http://www.powermate.com/accessories/product_detail.php?cat_id=9&model=PA0650192
May 24, 2010 | Coleman Powermate Premium Plus 6250W...
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
Electronics - Others Logo
161 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
