Question about General Electric DWXR483EGWW 6.0 cu. ft. Electric Dryer
Squeaking and want to know how I can fix it please
  • GE Master
  • 2,374 Answers
Most likely it is either the belt or one or more of the wheels the drum rides on. a belt stretches as it ages and can start to make noise as it slips on the drum or motor pulley. wheels/bearing also can make noise as they wear. another possibility is the tensioner that takes up the slack on the belt. if the dryer is 5+ years old or older, i personally would replace all the wheels(4) and the belt and lube the tensioner and have it all set for many more years. wheels are about $40 on eBay and the belt is about $10. other good sites for getting the correct oem parts are repairclinic.com(not the cheapest but always good parts and good return policy) or appliancepartspros.com(good prices/oem parts)
Posted on Apr 02, 2015
How do I fix that irritating squeaking noise?
More than likely an idler pulley assembly issue. Best bet is to order a replacement. You might as well replace the drum belt too since it means a complete disassembly of the unit for proper access, cleaning and repair. If you don't have the know-how it's best left to an experienced technician.
Jun 29, 2014 | Frigidaire Dryers
Sounds like your motor and/or pulley assembly are bad. Try turning the drum by hand. If it turns with some effort then you may have a drum bearing going bad. Does the squeaking sound start right away? Or does it start when the dryer warms up? If so then the bearing is going. If you can get to it spray WD40 for a quick fix.
Jul 11, 2010 | Frigidaire Dryers
My crankshaft is very wobbley and make a very high pitched squeak
You need a harmonic balance. Very common problem!
May 21, 2010 | 1995 Geo Prizm
Hotpoint dryer squeaks at regular intervals
Slow squeaking or scraping noises are often from the rear bearing behind the square panel, the rear bearing sleeve is inside the middle of the heater housing and the shaft part is attached to the back of the drum by a "C" clip which needs to be removed first.
The disassembly slideshow is here:
Slideshow
Sep 26, 2009 | Hotpoint TDL15 Electric Dryer
Phone wont vibrate
ok i dont know if this solves the problem for good, but i do know that it solves temperately. I went to phone settings and set the ring tone profile to vibrate. then i kept pressing the play button until the squeaking went away. It seems as though once the little moter in the phone goes at a constant speed it stops squeeking. the squeaking stops for a good while and is better than nothing. Someone tell me if this works for them. thanks ;]
Apr 17, 2009 | T-Mobile Wing™ Smartphone
Squeaking front end
It would be your bushings. Every blazer in the usa seems to have this problem. You think for 25 years of making them, they would fix this problem.
Feb 11, 2009 | 2001 Chevrolet Blazer
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Squeaking!!!!
see the video on bearings
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Nov 19, 2007 | Dryers
Squeaking noise when printing
Probably, but you?re going to have to try to isolate the problem a little better. Typically this would involve removing side panels and such; however, you may just have a faulty consumable like a toner cartridge, fuser or more likely the transfer kit. I typically try to isolate the sounds location then try replacing some of the consumables in that area one by one. In your case if you can?t isolate the location I would start with the transfer kit since that has a greater chance of making noise. Let us know what you find out and please don?t forget to rate the posting when we?re done.
Feb 02, 2007 | HP Color LaserJet 5500hdn Printer
This is a duplicate posting; here is the link to the active posting: http://www.fixya.com/support/t132706-squeaking_noise_when_printing
General Electric DWXR483EGWW 6.0 cu. ft. Electric Dryer Logo
79 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
