Could not open connection to server - Computers & Internet
How can proxy server bolked ?
A proxy server is a computer used to act as the one contact point between your computer and the open Internet. The primary benefit of a proxy server as that it can cache (store) Internet web pages and other content on its disc drives. When a user connected to the proxy server requests a web page or content that was previously accessed by another user, the proxy server can deliver that content/page from its cache to the new user without having to go out to the Internet.
Network administrators can configure a proxy server to prevent users from reaching dangerous or unauthorized web sites. So if your computer is connecting to the Internet through a proxy server, you will be using whatever restrictions the network administrators have set up. If you are not using only your home network, you are most likely NOT using a proxy server. If you are using a school, university, organization or corporate network, then you are most likely USING a proxy server to connect.
Feb 28, 2015 | Computers & Internet
HOW CAN I CONFIGURE MY HANDY CAFE SERVER AFTER I INSTALL
cant view my client in handycafe my net and router r ok last night i can view but now there gone
Mar 01, 2012 | Ates Software HandyCafe
The software does not eve open and I get a message that Says " A network-related or instance-specific error occurred while establishing a connection to SQL Server. The Server was not found or was not...
This is a tougher one! Sometimes when you open the software too fast before thedatabase starts up, you get this. Make sure the SQL Server services are running in Windows before opening RPE
Jun 06, 2011 | Pc America Restaurant Pro Express
Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 127.0.0.1... [VIP Raw] Resolving host name 127.0.0.1... [PASSED] [VIP Raw] Connecting to Virtual IP server 127.0.0.1... [VIP...
Try this solution:
1. Open your Yahoo! Messenger
2. Click <Messenger> Menu and Select <Connection Preferences> and another window will open.
3. Under <Connection> choose <Connect directly to the Internet>
4. Click Apply and OK
5. Re-open YM.
Hope this may help.
Thanks & Regards,
(-_-)
Mar 24, 2011 | Yahoo Messenger
I have a netgear n150 hooked up to my gateway laptop running windows 7, my gateway laptop running windows xp allows an internet connection but my gateway laptop running vista will not allow a wireless...
There might be a problem w/ your IP address or DNS server, try to open LOCAL AREA NETWORK CONNECTION STATUS in your laptop running xp, click support/details, Then copy the DNS server address and alternative dns server address.
open your vista go to Network Connection/LAN properties, then double click Internet Protocol (TCP/IP, mark obtain ip address automatically, then the lower side Mark USE THE FOLLOWING SEVER ADDRESS then paste the dns server address which you copied from xp laptop. same w/ alternate dns server, and then click OK. DONE.
JUST TRY IF ITS HELP FULL.
Jan 15, 2011 | NetGear WIRELESS-N 150 ACCESS POINT WRLS...
clear your Cache and History from/through IE. Try re-opening http://www.yahoo.com on IE then try logging into Yahoo Messenger again.
either manually or try this free tool
http://www.piriform.com/ccleaner
download, install, run cleaner, and then registry options
hope it works for you
Nov 19, 2010 | Yahoo Messenger
The setup wizzard does not see the print server
Is your print server and the computer connected to the router with the Ethernet cable. if not then connect both the print server and computer to the router with the cable.
then try it.
you can press the reset button on the print server for 5 to 10 seconds and you will get a print out ( printer should be connected to the print server).
on this print. you will find the IP address of the print server.
try to open the print server set up interface of the print server.
Click Here for more information.
Oct 05, 2009 | Computers & Internet
MySQL server at 'reading initial communication packet'
is the post open to read the mySql Server data ?
Jun 07, 2009 | Sun MySQL
Remote Desktop via VPN problem
Make sure that the Active Directory setting for the User you are using to RDP with (LDAP FQN) has the remote access option turned on.
http://www.windowsecurity.com/articles/Securing_Remote_Access_Connections.html
Also make sure that the PC's you want to access have static IP addresses. Not sure if that was mentioned.
Feb 18, 2009 | Dell PowerEdge 2600 Server
Cannot find License Server
1. TS and TS licensing server are installed in the same 2003 server. The lsview doesn’t list any TS licensing server.
2. If you open the Terminal Server Licensing, it shows “Finding servers… Connecting to \\apps\chicagotech.net. It never finds the apps server. There is not apps server in the network (They might remove this server from the network). After finishing the finding, there are two activated licensing servers listed, one is Windows 2000 server as 2000 TS licensing server and another one is Windows 2003 (also TS) as 2003 TS Licensing server.
3. The 2003 TS Licensing shows they are using Temporary License.
4. We modified the 2003 TS registry to point Licenseserver to itself (TS and TS license are the same server). That fixes the logon screen slow showing issue but not TS licensing issue.
for further querry
post comment
Oct 16, 2008 | Sibelius Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
