Question about Garden
How do i check my carburater?
My mower turns over but will not start.I changed the spark plug and solonoid.
  • 3,519 Answers
Hi Mo:
You need spark and fuel for it to run, and the spark has to happen at the right time. What happened right before the problem? Sometimes the key in the flywheel will get partially sheared and will retard the timing so it won't run. Check for spark at the plug. It should be blue and "hot".
Safety First! Mowers can bite, and we all need our fingers.
Posted on Apr 02, 2015
My wheel horse 212-6 ride on mower turns over but won't run iv'e checked the spark plug its good iv'e checked the fuel is flowing and its good also it still won't start please help????
Check fuel is fresh and change the spark plug for a new one. I had the same problem which was cured with a new plug. Also check whatever mechanism your mower engine has to provide a rich mixture for the initial start (choke)
Aug 04, 2016 | Garden
Have water in the carburater
Drain the water from the carb.
Drain the fuel from the tank. Check your fuel supply to make sure it does not have water in it, then re-fill the tank.
If you tried to start it with water in the carb, the plug may be wet. Remove it and dry it with heat. Check for spark while you have the plug out, then re-install.
Machine should start and run fine.
Back to work!
Mar 12, 2015 | Husqvarna Yard Tractor
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Engine cranks starts but will not continue to run
check to see if you have spark if no spark unplug the connector on the side of the engine and recheck for spark if you have spark with the connector off it's a bad safety switch
Jul 06, 2012 | Garden
MTD Yard Machine 22'', 4.5HP, 190cc push lawn mower won't start
The primer bulb might be damaged, or the carburator diaphram could have been damaged if carburater cleaner was used.
Jun 14, 2009 | Garden
Briggs & stratton 4hp push mower
why dose my motor cycle up & down in rpms
Jun 01, 2009 | Mtd 22" Yard Machine Push Mower
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
