Question about Garden
How do i check the carburator cuz my mower will turnover but won't start?
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
A quick shot of carburetor cleaner in the carb acts like starter fluid. If it is sparking, it should rev faster or try to start. If no spark, it won't even react.
Posted on Apr 02, 2015
    Problem Solver:
  • 16 Answers
Pour some gas in the air intake of carb but just a small amount. If it doesn't hit then it's probably your spark.
    Problem Solver:
  • 16 Answers
Depending on how many hours you have on the mower, it might be as simple as replacing the spark plug. The starter is turning the engine over, but you are not igniting the fuel. I would also recommend adjusting the carburetor once you get it running.
  • 3,519 Answers
Hi Again Mo:
A quick check would be to remove the air filter and prime the carb with a little squirt of gas. Sometimes they will start and keep right on running. My Craftsman has had that problem since the day I bought it new.
My powermore engine won" turnover. Starter sounds scratchy
First make sure you battery is up to full charge then you may have to pull the starter and take it to a repair shop and get it checked out. Sounds like you need a replacement. Also check battery cable both end and make sure they are clean and tight before doing anything.
Apr 25, 2016 | Garden
Mower wont turnover at key switch
Mower has multiple safety switches, seat,&hydraulics, also a bad PTO switch will cause them not to start.
Jun 19, 2014 | Toro 52" 27hp Z Master Zero Turn Lawn...
Lawn mower won't turnover..
Low battery power. Charge or replace battery.
Mar 19, 2013 | Toro Garden
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Starts, but wont run, stops running after a few minutes-then wont start for several minutes. Changed oil, spark plug is good-cleaned carburator, checked air filter.
You didn't mention what machine you're referring to. My guess is that is is still the carburetor. You missed something. Happens to me all the time. Sounds like a fuel problem if it "Starts, but won't run".
James
May 23, 2011 | Garden
The lawnmower won t start after pulling the start up cord . changed the spark plug it still won t start
try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline.
Jun 27, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Won;t start
I got a new air filter for mine today, plus cleaned out the metal fuel canister under the carburator and the little brass bolt and my mower started right up. I was having hte same problems getting my mower to run and stay running. Glad I checked this site!
Sep 09, 2009 | Mtd 22" Yard Machine Push Mower
Yard machine riding mower will not start
check all of your known safety switches!
Clutch has to be pushed in
seat switch (sit on mower)
blade disengage switch
Finally check your starter soleniod between the battery and the starter and look for fuses and check them out in the process
May 18, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
