Question about TimeWarner Cable Time-warner cable on-demand 4 device universal remote control new
New remote went through the process on back of remote and it did not work, it did work on the tv in my living room , just not in my bedroom???
    New Friend:
  • 18 Answers
Two different tv's either one or the other, can't have both my friend.
Posted on Apr 02, 2015
N64 No Picture on Vizio TV
Well it sounds like a coincidence then. Or if it's working on one tv and not another tv then you need to try a new av cable to see if it makes a difference.
Oct 13, 2012 | Nintendo 64 Console
Bedroom remote doesn't work
weak batterys wont hold codes on it huh?
Sep 24, 2012 | DISH Network Televison & Video
I have one receiver in my living room. The living room tv is on the #1 channel and the kitchen, guest bedroom and master bedroom tv's are on channel #2. All remotes were working just fine and suddenly...
Hello! On the back of your receiver box you'll see a silver UHF antennae make sure its pointing straight up. If that fails try the steps in this link
http://www.dishnetwork.com/SupportSection/remote-setup
Daniel Busa
DISH Network Customer Service
Jan 04, 2011 | Universal Remote Control DISH Network...
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
The two TV are synced. Do I unconnect them? I have one TV in the living room, one TV in the bedroom. Whenever the TV in the bedroom is on, it is on whatever channel is on in the living room. Both remotes...
If you have a dual tuner it is in sigle mode. Go to the front panel on the receiver and press the mode button. This may be behind a push open door based on the receiver you have. If this does not work let me know. Thanks for using Fix Ya.
Aug 15, 2009 | DISH Network IR Remote Control
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
I have a bedroom ceiling fan that recently started to have a surge issue. It was working fine before (although the remote control for this fan also worked on the Hampton Bay fan in the living room and the...
Sounds like you could have a problem with the fan....but there is also an equaly good chance it's the wiring of the fan. Perhaps a loose connection. If you are not familiar with checking electrical connections, you probably need to call an electrician to check the wiring SOON, before there is a short. If all connections are good, then you will know it's the fan (or the remote receiver on the fan).
Hope this helps!
Chad
Oct 14, 2008 | Hunter 52" Ceiling Fan With Light And...
Universal remote
only a uhf remote will work from that location, you will probably need to get a dish network 6.0 or 6.3 remote
Jul 04, 2008 | DISH Network 322 DTV Receiver
Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Mar 03, 2008 | Logitech Harmony 880 LCD Remote Control
TimeWarner Cable Time-warner cable on-demand 4 device universal remote control new Logo
55 people viewed this question
Top TimeWarner Cable Televison & Video Experts
Tom Chichester
ray gallant
Are you a TimeWarner Cable Televison and Video Expert? Answer questions, earn points and help others
