TL-WR841N is a modem i have From TP-Link which Was Accidentally Disconnected . And Now when Connected Again, During The reconfiguration [from The Easy Setup Gide that came with the modem]- The Setup always gets stuck at- *Checking Network Status* .I have tried A lot Of Means to fix this but none of them are working. Also I have a Local Service Provider. And also i know All my Lan TCP ip4 Settings.. Please Give Your Answer Accordingly.. Im in need of help. :)
SOURCE: D-Link DI-524 works with desktop, but laptop can't get signal
Try opening internet explorer and typing in http://192.168.0.1 in the address box
If this doesn't work try http://192.168.1.1
For the username and password put admin for username and leave the password blank
Now look for an option for the Wireless Settings and change the channel from usually channel 11 to channel 4 your laptop may now see it. Otherwise try another, channels available in the uk are 1-12, I think it's 1 to 11 in USA
SOURCE: Have D-Link G604T router/modem and want to connect
Dear,
I think this will help you
http://www.tp-link.com/support/showfaq.asp?id=151
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
SOURCE: Belkin (F5D8235-4) with Tp-Link TL-WR702N as a repeater
It needs to be configured as a repeater first.
http://www.tp-link.com.au/article/?id=397
