Question about Food Processors
On button acts like pulse button
It was knocked off the counter and the on button now acts like the pulse button, it doesn't stay on unless I'm holding the button down. Occasionally when we knock it around a little it will stay on. Any suggestions?
    New Friend:
  • 18 Answers
Replace switch, sorry didn't mean to say the obvious. Just good like that I guess
Posted on Apr 02, 2015
KitchenAid KFPM770 motor runs 3 seconds and stops
Determine first if it really is the motor. Does it only cut out if loaded or will it happen without any load? Remove all bowls and blades, plug it in and turn the power on and press the on button. With something plastic press the small white button that is in the middle above the switch panel and normally hidden by the bowl. This is the safety cutout switch avtivated by the bowl, lid and pusher being in position. Does the motor run while the button is depressed or does it again cut out after a short time but with button still depressed. If it doesn't cut out it's likely that wear in the complicated mechanisms in the lid and bowl handle are releasing the cutout switch with small vibrations of motor running. I figure out which one to replace by swapping out one of the 2 parts for a new one as I try to carry both parts in stock for that purpose.
Jul 11, 2016 | KitchenAid Food Processors
When the top section is clicked on and on button or pulse or dough button pressed it doesn't go. took top off and pressed the little black button to simulate top being put on and still no result.
Try taking the bowl off and pressing the safety switch with a screw driver. If the processor turns on then you have a problem with the bowl, if it doesn't turn on then the issue is inside of the food processor, and usually internal parts are not available.
If you can find your model & brand information off of the base of the food processor we can look up replacement parts for you.
Thank you,
colleen @ mendingshed.
May 12, 2015 | Food Processors
Kitchen aide chefs chopper Model KFC3100ER2 does not always turn on when pulse button is pressed
You need to replace either the bowl or the lid. Either the lid is not pushing the bowl mechanisms far enough or there is too much lost movement in the bowl part.
Sep 14, 2013 | KitchenAid KFP715 7 Cups Food Processor
Cuisinart DLC-8S Food Processor: On/Off Switch not working
Replacement of the switch would be a likely repair unless other damage makes replacement impractical.
Apr 14, 2017 | Cuisinart DCC Food Processors
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Can't figure out how to turn on Regal LaMachine I food processor
It's very easy--but you have to know the trick--I know 'cause it took me awhile to figure it out. Place the machine with the on-off/pulse button on your left. Lock the container in place--the handle will be on your right. Put the blade on the shaft. This is the trick: Lock the lid in place so that the shoot is directly in front of you and the "***" slides into the **** on the left of the machine (between the container and the inside of the machine, left of the on-off button). Good luck!
Nov 25, 2008 | Regal Ware K813BK La Machine Food...
Food processor
I phoned the 800 number at Cuisinart (800-243-8540) and the person who answered the phone explained to me what to do: Fill the bowl with the hottest tap water I have (but not boiling) above the entire blade (including the part that fits over the shaft). He said to pulse a few times, then try to pull it off, but not to expect it to work right away. He said to do this until it comes off and that it could take 1/2 hour. I did what he said, and the blade came off after the first pulses. But also, the water was pouring out all over the counter--leaking between the bowl and the base (possibly because my old work bowl is also cracked, but I'm not sure).
I was told that the problem would happen again, and that I needed replace the blade and the shaft (which is cracked, as he guessed), both of which are available from Cuisinart.
Oct 07, 2008 | Cuisinart DLC-5 Food Processor
Euro pro food processor and blender combo
Defective pulse button or blender attachment not installed correctly.
Sep 12, 2017 | Euro-Pro EKP110 6.25 Cups Food Processor
Cuisinart won't pulse
I started from scratch with the assembly instructions. Got it together correctly and now everything works.
Mar 03, 2008 | Cuisinart DLC-2011 PowerPrep Plus Food...
Food Processors Logo
123 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
