Question about Microsoft Computers & Internet
If i download a pc operating system to a usb, do i have to put it in a folder with a specific name so that if i where to install it the pc should recognize it?
    New Friend:
  • 5 Answers
If I were you I would just use this http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
It creates a bootable disk drive usb and has many many supported distros from Linux to windows 8. If your using it to boot windows 10 just use the windows 8 option as it worked for me.
Posted on Apr 02, 2015
Testimonial: "Thanks for ur help,i was able to make it work with this. :)"
How do I move a copy of Quicken from my desktop to my laptop.
Hi.
When you downloaded quicken, it should by default save to a sub folder named "Download" Depending on your PC's operating system, the download folder is normally found in the "My Documents folder" Click on the Start buttom (Windows) in the bottom left corner of the taskbar. Inside the Download folder should be a file with the name Quicken.exe. Copy the Quicken.exe file to a memory stick or flash drive, then stick in into the usb port of the other PC. Click on the Quicken.exe file and it will run the installation of Quicken on the second PC. Install Quicken the same way on the 3rd PC.
Good luck!!
Apr 07, 2014 | Computers & Internet
Need original drivers for hp6119h
You can download them by going to google's website (www.google.com) and type in: "hp support" (without the quotes). Look for drivers and downloads and click the link to the site. Once there you will be asked for your computer's model and the operating system. Put them in and it will show you all the drivers for your system that you can download and install.
Your drivers might be already on your system. Click Start/My Computer and select the c: Local drive. Look for a folder named SWSetup (Software Setup). If you don't see it look for a folder named HP or Hewlett Packard and inside those folders see if you see a folder named Drivers. If so click on the drivers folder and run the setup by clicking on Setup for each driver.
Mar 21, 2012 | Computers & Internet
How i install yahoo messanger in my pc
Download Yahoo Messenger for your operating system from Yahoo. Then look for and run the exe file in the folder you saved it to and that will install it. It will install it to the C drive and put a shortcut on the desktop. You will then need to pick a user name and password.
(If you choose RUN when the download window pops up instead of SAVE it will automatically install it for you and make the shortcut)
Feb 16, 2011 | Computers & Internet
My ps3 has error 80710723 and says it needs to update. when i try to update it i get the error and cannot connect to the network.
Download the update from your PC save it on a usb flash drive. On the flash drive create a folder and name it PS3 and inside of that folder make a folder and name it UPDATE. Save the download into the file that you named UPDATE make sure you name the downloaded file PS3UPDAT.PUP.
Put the usb into a usb port on your PS3 and goto system update and do the update via storage. Make sure the files and the downloaded contene named files are all in upper caps.
Feb 08, 2011 | Sony Video Game Consoles & Games
Its telling me the hard disc is corrupt and is reloading it but it doesn't fix it and takes ages but is the same
Your hard drive has a problem and needs to be formatted. this has happened to me twice already but not with the original hard drive that came with the ps3, I changed mine to a 500 gig drive which had the problems.
the bad news is that you have lost everything that you saved onto the drive and need to reformat and reinstall the ps3 operating system.
If you go through the system settings there is an option to format the drive. Do that.
Then you need to get a USB flash drive, and follow the steps below
Download the update and save the file to a compatible storage device such as Memory Stick, Memory Stick Duo, a USB or PSP.
Before starting, use your PC to create a folder named "PS3" in the storage media or USB. In this folder, create a folder named "UPDATE" (the folder name is case sensitive and must appear in capital letters). Once the UPDATE folder is created, download and store the update for PS3 system software.
Once the update saved, remove the storage media and connect to your PS3 via the slots under the slot cover, or USB, depending on the storage medium used.
Once the storage media connected, go to Settings on the home menu of the PS3, select System Update, then update via Storage Media. Select the storage media connected to the PS3 installs the update data stored there.
Good luck.
Dec 06, 2010 | Sony Playstation 3 (PS3) Console
Windows vista
Yes you can get download recovery discs, Hiren's Boot Disc, BartPE, & Live distributions, such as Linux, or indeed the operating system install DVD. These all can be used to do so.
Jan 28, 2010 | Samsung MOBILE NOTEBOOK Q310-34G SYST2.0G...
I downloaded the update but the pc cannot open the file . the updater is called eboot. i have it in my pc but cannot open it
The file is not supposed to be opened by your PC. You have the transfer the file from your PC to the PSP. To do this, you need a USB cable and you have to plug your PSP into your PC.
Download procedure
  1. Prepare to save the update data on either system storage or Memory Stick Micro™ (M2)™ media, using one of the following methods:
    • Connect the PSP® system to the PC using the USB cable
    • Connect a commercially available Memory Stick USB reader/writer to the PC
    • Use the Memory Stick slot on a PC
  2. Create a folder for the update data on either system storage or Memory Stick™ media.
    Using your PC, create a folder named "PSP". Within the "PSP" folder, create a folder named "GAME". Within the "GAME" folder, create a folder named "UPDATE". (Folder names must be in all uppercase letters).
  3. Download the update data for the PSP-N1000 (PSP®go) series and save it in the "UPDATE" folder created in step 2.
Notice
You must save the downloaded data as noted in these instructions. If you do not save in the correct location and with the filename shown below, the system will not recognize the update data.
  • Filename: Save as filename "EBOOT.PBP"
Nov 19, 2009 | Sony PlayStation Portable (PSP) Console
Games downloads
Through USB cable.to your game folder
Apr 07, 2008 | Sony Ericsson V630i Cellular Phone
Pes2008
That's the best way to do over your PC to your USB. Create a folder on the storage media in which to save the update data.
Using a PC, create a folder named “PS3” on the storage media or USB device. Within the PS3 folder, create a folder named “UPDATE”.
  • Download the update data and save it in the UPDATE folder created in step 1. Select here to start the download.
Notice
Be sure to save the update data as noted below. If the data is not saved in the correct way, the PS3™ system will not recognize the update data.
  • File name: Save as file name “PS3UPDAT.PUP”.
    Update procedure
Notices
  • Do not turn off the PS3™ system or remove the storage media or USB device during an update. If an update is cancelled before completion, the system software may become damaged, and the system may require servicing or exchange.
  • The power button on the PS3™ system front is not active during an update.
  1. Insert the storage media or USB device that contains the update data in the PS3™ system.
  2. From the home menu, select (Settings) > (System Update), and then press the button
The folder name must be in all uppercase letters.
    Update procedure
Notices
  2. From the home menu, select (Settings) > (System Update), and then press the button.
  3. Select [Update via Storage Media], and then press the button.
    The system automatically searches for and finds the update data saved on the storage media or USB device.
  4. Start the update data.
    Press the button to start the update data. Follow the on-screen instructions to complete the update.
  5. Confirm that the update was successful.
    After the update has been completed, go to (Settings) > (System Settings) > [System Information]. If the System Software field displays the version number of the update, the update was successful.
Hint
You can delete the update data from the storage media or USB device after the update has been successfully completed.
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
