Where can i get a cover for the battery compartment?
Digital Executive Safe #SL130150088
  • 3,320 Answers
Try ebay or just search Google for dealers. eBayeBay
Posted on Apr 04, 2015
    Novelist:
  • 144 Answers
Battery covers are typically a dealer item if you want a new one, or you can often go to to a wrecking yard for a used one, if they have a comparable vehicle in the yard.
Posted on Apr 02, 2015
Bull Safe with two doors and 3 door front load. Battery compartment on both doors are broken. Currently held by tape. Is it possible to order a replacement cover to hold the batteries securely?
You should be able to purchase replacement parts..Check your manufacturers Website /support page ..and check eBay also . Good luck
Nov 16, 2016 | Cameras
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    Where do you replace the battery on this safe and what kind of battery
    Although the following is applicable to most Safe, you model may differ.
    The hardest part about changing the battery in a digital safe is finding where it is. But don't worry, it's not inside. The battery compartment is under the keypad, and has a little tiny hole for removal. If you don't have a jeweler's screwdriver that is small enough, you can use a straightened-out paper clip. The battery is a 9 volt.
    Things You'll Need
    • Jeweler's screwdriver or paper clip
    • 9-volt battery
    • Insert the jeweler's screwdriver or paper clip into the small hole in the plastic panel, just below the keypad and to the right of the keyhole.
    • Slide the panel to the right.
    • Carefully pull the old battery out.
    • Carefully unsnap the wire connector from of the old battery. The connections are like clothing snaps and just pull off.
    • Snap the connector onto the new battery. Be sure to observe polarity--it will fit only one way.
    • Carefully put the new battery into the battery compartment, storing the wires out of the way of the cover.
    • Insert the cover in its slots, and slide it back into place with the jeweler's screwdriver or the paper clip.
    Mar 09, 2016 | Home Security
    Need to change safe combo. I have the current combo. The safe is an Executive Vault EV-600.
    Best bet is to contact Executive Vault on Monday. Each safe and safe manufacturer has specific details. Sometimes you cannot change the code.
    Jan 06, 2013 | Toys
    Hello, I have a Sportline Digital Motion Sensor.
    Do you mean the screen is blank or you cannot remember how to program it? Was it working perfect until you replaced the Battery?
    Make sure the battery is inserted with the positivet side up?
    Manual is here: http://www.sportline.com/manuals/370.pdf
    Replacing the battery: 1. Unscrew the battery compartment cover on the backside of the unit using a small Phillips screwdriver and remove the cover. 2. Remove the exhausted battery from the unit, and insert a new battery (be sure to place the positive (+) side of the battery is visible, facing toward the battery compartment cover). 3. Replace the battery compartment cover on the battery compartment and fasten the screw (CAUTION: do not over tighten).
    Dec 14, 2010 | Sportline 370 Traq Motion Sensor Pedometer...
    Just replaced batteries camera is brand new and wont turn on
    Remove the backup battery. You will see a rectangular insert inside cover of battery compartment, closest to the hinges, pull out using fingernail. Close battery compartment with batteries inserted, turn on. Turn off open battery compartment replace backup battery. Reset date and time.
    Jul 18, 2010 | Canon PowerShot A490 Digital Camera
    Have a Vivitar v335 older model camera, think maybe early 80s. It's not digital, and need a battery. Several "experts" have told me a Duracell 28L is what I need but batter is too long. Battery compartment...
    I happen to have one also. I bought it in the mid 80s. I still have the original box and instruction manual. It says: "Holding the Battery Compartment COVER in your hand, drop in and stack two LR44 or SR44 batteries so that the plus (+) signs are facing up. Replace the Cover. The positive (+) side of the batteries should face the (+) contact at the bottom of the battery COMPARTMENT. Turn the Cover clockwise with a coin until it stops flush with the bottom plate of the camera. DO NOT OVERTIGHTEN".
    Sep 11, 2009 | Vivitar ViviCam 3915 Digital Camera
    I have a sentrysafe t6 mode i cannot open as battery is dead
    Locksmiths install sentry safe batteries this way
    slide open the battery cover located just below the keypad.
    Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the sentry safe battery holder Insert the 4-batteries as indicated.
    reconnect the connector and put back the battery holder. Slide the cover back in place.
    How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
    turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
    Jun 07, 2009 | Sentry Fireproof Safe
    Broken Battery Compartment Cover
    I haved the battery cover ,call me 786-4361121 new original nikon
    Dec 18, 2008 | Nikon COOLPIX Cameras
    All-weather
    The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt-water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
    Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
    Computers & Internet Logo
    122 people viewed this question
    David Payne
    David Payne
