Question about Garden
DB 917- 60110 tiller. What would it be worth ? Very good shape just needs carb cleaned
  • 86 Answers
SOURCE: Need new carburetor
I will check to see if I can get you one at a resonable price.
Posted on May 13, 2009
  • 112 Answers
SOURCE: Echo tiller doesn''t want to run
you may need a diaphram in the carb or the tiny screen (if it has one) is plugged. Also check hoses to and from tank make sure they are good and not soft and gooey. You could draine tank and put pure gas in and use primer bulb to circulate it then remove gas and add mixed gas. long shot but may work, has for me.
Posted on Jul 15, 2009
  • 112 Answers
SOURCE: Statesman Tiller
without knowing if its a briggs and straton or tecumseh engine ( I assume Briggs) the carb is where the throttle and gas line connect to. carb will need to be rebuilt most likely and tank will have to be removed to be cleaned. you can email me and I could do it for you I am in wisconsin kerryjonjon at yahoo.com I am the most reasonable in this area. I could do carb and tank if you want.
vincob
  • 718 Answers
SOURCE: Have a Yard machine Tiller, believe the model #
I needs to be cleaned!! It's clogged up in there with old varnished fuel..Clean thoroughly!!!! Good Luck...
Posted on Apr 19, 2011
  • 17 Answers
SOURCE: Poulan tiller with 85 series engine 8.5 hp will
Sounds like the float valve is stuck. This means that there is not enough gas coming in. Try some solvent such as berryman's b-12 chemtool. First drain gas from system, then use only enough solvent in fuel tank to fill carb bowl. Let is sit for several hours and then drain the bowl. This will dissolve any gum that has formed in the carb and will free everything up. I would try this before making any modifications to the adjustments.
Posted on Mar 23, 2012
What is a 1969 troy built tiller worth in great shape?
I sold my pony 5hp in good shape in Canada for 275.00. At that price I had a number of people wanting it. Cheers to you!
Sep 21, 2014 | Troy-Bilt Garden
Engine surges at idle or any speed
That is called hunting and can be caused by various things. The governor controls the engine speed. Is the lever and link/spring correct. Carb in good shape? Spark plug clean and gapped? Fresh fuel or was there old fuel in it?
Aug 22, 2010 | Troy-Bilt Pony Garden Tiller
4.0 Tucomsa engine on a 4 year old troy built tiller
YOU MAY NEED TO ADJUST THE FLOAT. IN THE CARB.THERE MAY BE "STUFF" IN THE FUEL BOWL THAT NEEDS TO GET CLEANED OUT.YOU MAY HAVE A FUEL LINE PINCHED OFF OR THE FUEL CAP VENT MAY BE PLUGGED.HOPE THIS HELPS.
Oct 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a roto tiller with carb problems it was
carb needs a good cleaning or probally rebuilding it would be your better choice
Sep 22, 2009 | Ryobi Cultivator
Having carburetor problem with honda f210 tiller and it won't stay started
I need the year make and model. This sounds like you just need to adjust the idle screw or clean the carb with some carb cleaner and it should be good to go
May 16, 2009 | Honda Garden
Need new carburetor
May 07, 2009 | Garden
My push mower has a 6.5 B&S and will only run if you keep pumping the primer i already disassembled the carb and cleaned the jet also checked bowl float all ok
eeeeerrrrrrr, breaks and scrap it...lol
well you saying that it stays running only while pumping the primer tells me that it is running lean(carb needs adjusting), it maybe the fuel line is plugged not allowing enough fuel to flow.
May 01, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I cant get my tiller to rev up.
most problems are due do a fouled carb, because of old fuel most of the time, take the carb off and separate it from the tank and give it a good cleaning and replace with new gaskets and carb parts, use carb clean and air pressure to clean,
Apr 21, 2009 | Garden
5 hp Briggs and stratton wont run on a MTD tiller.
I had the same problem a few years back. Check the rubber elbow coming from the gas tank to the carb, it's probably cracked and sucking air instead of fuel from the tank.
Nov 30, 2008 | Garden
Garden Logo
51 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
