Question about HP Pavilion (PN153AAR) PC Desktop
Cd rom drive does not work! NEEDS ASSISTANCE!
My cd rom drive does not work. everytime I put a disc inside it wont scan the disc. whether the disc is empty or full it wont scan the disc i checked everything how come it won t work
Re: cd rom drive does not work! NEEDS ASSISTANCE!
Magnit can damage your Cd drive, maby it is damaged.
Posted on Nov 14, 2007
0 characters
3 Points
My CD burner has stopped working. I get a message that a disc needs to be inserted when one is already there.If I take it out and put it in again. (These are new discs.) I receive the same message. I refer...
Use a cd-lens cleaner for first step u will get this in computer shop.
u have wet and dry method choose one
if u are used to remove the cd-rom drive unscrew the cd-rom drive open it and clean the lens with a dampt cotton cloth then with a dry cotton cloth
Nov 12, 2009 | PC Desktops
CD-Rom not reading cd's
it sounds like the cd rom driver in windows is not installed correctly try reinstalling the cd rom if that does not work the cd rom needs replaced
Sep 02, 2009 | Dell Dimension 4500S PC Desktop
Hard drive not Reading CD-R Discs
First off. Your hard drive cannot read CD's. Your CD-ROM is not reading CD's. Well a few things can be wrong there. 1. The CD-ROM is dead 2. The drivers for the CD-ROM needs updating 3. The CD that you are trying to read is curropt or damaged.
Start checking to eliminate and let me know.
Aug 13, 2009 | Acer America Co - Aspire Desktop 4GB 640GB...
Cannot get CD-ROM to work,to come up on screen.
Ok with that you need to insert the disc and then go into the my computer section of your computer and then in the CD rom drive you should see the disc and you will click on it to start the process. However if that does not work then your CD rom drive is defective and you need to purchase a new one.
Jun 17, 2009 | PC Desktops
The cd drive aint reading blank disc
You must have the burner program (roxio or nero) identify the CD/DVD RW Drive. If the burner program didn't come with the drive at the time of purchase go to roxio or nero site and look for updates for your particular drive. If you don't have that info...look in divice manager under CD/DVD-Rom Drives and it will tell you.
Failing that...look for updates of "Firmware" at the manufacturer of your drive...
Good luck...hope this helps
Apr 23, 2009 | PC Desktops
I have a Toshiba CD-RW drive that keeps ejecting everytime a put a disc in, why
install any best anti virus(kaspersky,eset nod32,....) an update it online and scan, if problem reminds than the problem with your cd-rw drive need to be replace....
Apr 10, 2008 | PC Desktops
I hate my computer!
No, this doesn't cost unless you sign up for Premium Assistance.
  1. Remove the disc from the drive.
  2. Look at the top of the disc (or game box). Verify whether it is a CDROM or DVD-ROM.
  3. If it is a DVD-ROM, verify the drive on your computer that you are inserting the disc into is capable of reading DVD-ROMs.
  4. Go to My Computer and verify which drive letter is the drive you'll be inserting the disc into.
  5. Insert the disc.
  6. Wait 20 seconds. If the disc doesn't automatically start up, go to step 7.
  7. Open My Computer and double click the drive containing the disc.
  8. If My Computer now shows the disc contents, find the most likely ".exe" file and run it.
Mar 06, 2008 | PC Desktops
My Computer Wont Read DvD's or CDs!
Is the CD drive display in my computer? yes
then clean up your CD/DVD rom for there is dust in it, specially on the lazer lens that let the rom read the CD/DVD.
If no, then; Fix some cable connection towards your CD/DVD rom for it was lessen.
If not fix the problem verify the disc if it is readble by your Rom. Please try another disc in your Rom.
if same happen, then maybe its time for a new CD/DVD ROM.
one last try:
try your new purcahse disc in another computer that is compatible with your disc.
hope this help, melnavz
Feb 05, 2008 | Dell Dimension 3100 PC Desktop
Open Questions:
See all HP Pavilion (PN153AAR) PC Desktop Questions
HP Pavilion (PN153AAR) PC Desktop Logo
103 people viewed this question
Top HP PC Desktops Experts
Fred Sops
john smith
 Mike M
Mike M
Are you a HP PC Desktop Expert? Answer questions, earn points and help others
