Question about Jacuzzi Home
I have a jacuzzi 470 hot tub.The skimmer that bobs up and down is stuck down and I can't pull it back up.Advice?
    Top Expert:
  • Jacuzzi Master
  • 45,294 Answers
Turn the pump off then try pulling it up
Posted on Apr 01, 2015
  • 10865 Answers
SOURCE: Leaking pipe in a jacuzzi hot tub
The only product I know of which will do what you ask is an item called Plast-Aid Acrylic and PVC repair kit. Google it and you will find the website. It is about $20. and it works like a charm. good luck
Posted on Jan 21, 2009
  • 80 Answers
SOURCE: heater pump does not turn on Jacuzzi hot tub 325
Heater operates seperate from pumps. Do the pumps come on? Pressure/flow switch turns on heater, so if the pumps work, there is an issue with the heater element, the flow switch will usually prevent the spa from running at all and there will be an error code on the control panel.
Posted on Aug 19, 2009
  • 491 Answers
SOURCE: water leaking due to faulty knob on jacuzzi whirlpool
replace rubber wasers
Posted on Oct 10, 2009
SOURCE: Garden jacuzzi tub start button is stuck. It won't pop back up
I called a plumber. He said push the button all the way in, put some 3 in 1 oil on the inside (you'll see a little indent) every couple of months. Also push and release the button quickly. Cost me $80, and he even used my oil!!!!
churchill
Posted on Apr 07, 2010
uspartscente
  • 717 Answers
SOURCE: what causes my jacuzzi hot tub to turn itself on.
sounds like you have an electronic system that operates the tub. Many times those get hit with a voltage spike and it burns up a relay on the circuit board and THAT is what make them come on at weird times.
You will most likely need a new control for your tub.
Posted on Jan 13, 2011
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Why is hot tub over-heating past max temperature?
Sounds like a problem with the thermostat.
Aug 05, 2014 | Jacuzzi Home
Odors coming from jacuzzi bathtube we hardly ever use it .but there an oder coming from it
The water in the trap could be evaporating over time and allowing sewer gas to enter the tub causing the smell. Try using some RV antifreeze in the drain. The antifreeze won't evaporate. Hope this helps.
. Bob
Jul 06, 2014 | Home
Newly installed jacuzzi only has hot water for about 30 seconds, then water is tepid only.
This issue will have nothing to do with the jacuzzi tub. You will find the problem exists in the way your home was plumbed by the plumber.
Somewhere there is a clog in the water line going to the hot water faucet.
Find that and you will solve your problem.
Rod
US Parts Center
Mar 06, 2014 | Jacuzzi Home
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
I have a Jacuzzi Cirrus, bought in 1996. It leaks slowly (I have to fill every 2-3 days. It drops about 8 inches and gets close to below skimmer. Do you know what could be leaking?
Each of the jets have rubber gaskets. The continual heat and cemicals starts to deterioate these and the tub leaks around the jets. This is not always noticeable do to the fact that the water is hot and tends to evaporate. But even a small leak multiplied by all the jets adds up. 1996 is a long time and the replacement of these gaskets are overdue. I hope this has helped it would be the first thing I would look at given the age. Hope this has helped good luck and have a great day. Jeff
Mar 29, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Looking for an inexpensive replacement skimmer for my hot tub. Skimmer is a Waterway 510-1500. Thank you, Jim
I fully inspected the skimmer for any cracks, filled it with water and found no leaks. Since it's 10 yrs old, I chaulked it up to wear and tear. I bought some 100% Silicon, applied it around the opening on the hot tub and the back of the skimmer and reinstalled. Letting the Silicon cure for 24 hrs which will be in about 2 hours and will retest. I'm pretty sure this should take care of my problem.
Feb 20, 2009 | Waterway Complete Skimmer, Front Access,...
Need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Nov 11, 2008 | Balboa Instruments Garden
Home Logo
257 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
