Question about Maytag Refrigerators
Maytag fridge buttons won't work properly with NEW control panel. Reset isn't working.
  • Maytag Master
  • 744 Answers
Hello DaVe;
My name is peter. I am a retired field service refrigeration technician.
What are you doing. You replace a control board and wasted your money.
Send me model number, which is located on the inside liner panel of your fresh food section on a label.
Please do not spend any more money guessing.
Posted on Apr 02, 2015
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
Krazytech
  • 725 Answers
SOURCE: Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Posted on Apr 05, 2008
  • 219 Answers
SOURCE: Maytag Freezer Door Panel Locked
replace the front board but read your manual first because some lock without it saying it has the lock feature by hitting 2 buttons for 3 sec at the sametime locks and unl;ocksit
Posted on Mar 19, 2009
localwonder
  • 6784 Answers
SOURCE: control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
Posted on May 25, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE side by side refrigerator model GSH25KGREWW
You said that the control board on rear of your refrigerator was replaced and there is still nothing happening? You do need to check the power behind the refrigerator to make sure there is power, yes.When did the control board get replaced and was it new?. Sea Breeze.
Posted on May 28, 2009
How do I reset or reboot my maytag fridge. I already replaced the control panel. MFI2568AES
SOME FRIDGES HAVE A RESET BUTTON IN THE CONTROL BOARD OR ON THE CONTROL BOARD
Apr 01, 2015 | Maytag Refrigerators
My Maytag MTB2156DEB fridge died. Electricity is on, lights are on but nobody home, I.E., no cooling. my old fridge had a "reset" button which I found out after the repairman charged a bundle to press. ...
Your model doesn't have a reset button, this is non-electronic. First, tap on control panel to see if cold control is stuck. (tap on beat) If it starts it could be a bad control. Does to compressor click like it wants to start? Lastly, there is a defrost timer within the control housing, with a screwdriver rotate the timer slowly to see if the timer is stuck. If the unit starts running it could be that the timer needs to be replaced. Get back to me and I can help further if needed. Good Luck
Mar 07, 2015 | Maytag Refrigerators
Maytag fridge model# MSD2561HES
Look inside the freezer for frost buildup on the rear wall. Let me know if there is frost building because that would indicate a defrost problem causing the warm up. Also check your model number because you are the only one on the internet with a model MSD2561HES for the USA Once you have the correct number and answer back about the frost buildup I will tell you each step to take solving this problem which I think is a defrost problem at this point, Thanks Sea Breeze I think your model has the adaptive defrost control board that may be at fault=> 4388932 Defrost Control Board
Aug 19, 2012 | Maytag 25.6 cu. ft. Side-By-Side...
Maytag mdb/c-2 some lights are blinking and won´t stop. I can´t start the cycle of cleaning, well really i can´t start anything. Please any sugestion ?
press the "off" button and hold it down for several seconds. this worked for me when i encountered the same problem on my maytag jetclean this weekend. it reset my control panel and now it's working great!
Sep 11, 2010 | Maytag 24 in. MDB5600A Jetclean II...
MSD2756GEB maytag. freezer is working properly.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jun 21, 2010 | Refrigerators
Control panel on my fridge
May 25, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
None of the buttons on the door will not work
Hi!! You should be able to unlock it from the dispenser control panel if not disconnect the frig for 5 minutes from the back of the wall and try again..Good luck..
Jan 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
No lights or ice/water available
go here and get a new manuel for free if futher assistance is required reply to me yes its a good site http://www.maytag.com/support/manuals_literature.jsp
Jul 10, 2008 | Maytag MFI2568AE Side by Side French Door...
Maytag dishwasher mdbh950awb
Sounds like you have a control panel and/or control board issue. Normally when operator functions fail or "halfway" work the main control board, associated keypad, or wiring are the likely suspect. Now...another remote possibility could be the door latch not closing properly. However, this would affect ALL functions. I hope this helps you.
Jul 31, 2007 | Maytag 24 in. MDBH950AWS Built-in...
Refrigerators Logo
126 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
