Question about Trust Quasar Headset
I've had this headset for a while now and the microphone hasn't been working for a long time. I have been looking for a way to fix it, but I have no idea. Any ideas?
There is no obvious physical damage, I have searched over the internet for a fix and found nothing. The microphone takes in no sound, and sometimes isn't detected by my computer. It seems to temporarily work on some computers before stopping again, and I am using a USB mic temporarily. Also, this headset uses audio and mic jacks.
Why won't my tablet support headsets with microphones while others without a microphone work absolutely perfectly?
If you take a look to the 3.5 connectors, you'll realise connectors are slightly different, that's why.
May 09, 2016 | Tablets & eReaders
Microphone Problem MSI / Realtek
disable your internal mic, go to start--type computer management--go to drivers-- sounds and audio-- right click, and disable the one you dont use.
Jun 18, 2013 | MSI Microstar GE60 0ND-257US 15.6" Gaming...
Microphone doesnt work with skype
I've heard of this problem alot, I took 10 minutes today with my friend with this headset to figure out a fix.
From what i can tell, Skype doesnt pick up the Microphones input.
The only solution I could figure out so far has been this.
A voice changing program called MorphVox Pro (by Screaming bee) offers a Trial.
If you download it, and set up your microphone on this to work, You can then in skype select the MorphVOX Pro as your microphone, and you can use this chat program to work with your headset.
This is only a temporary fix But it is a step in the right direction, I'll be forwarding my email to Razer later to try and get some updates for the headset.
Best Regards
Ricky.
Feb 09, 2013 | Razer Chimaera 5.1 Wireless Gaming Headset...
I have problem in plantronics dsp 400..regarding mike..i cab hear the incoming calls but i cant hav any conversation in mike..the end user cannot hear..so kindly rectify this problem..as it would be of...
<span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: navy; FONT-SIZE: 10pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">The first thing you need to check is your audio settings and make sure that both sound recording and playback are set to the same device. If you
Aug 19, 2010 | Plantronics DSP-400 Headset
Doesn't work with Skype
Fixed it: the microphone on the headphone was switched off - it's a bit of a design weakness in the Logitech headset: it's easy to unintentionally turn the microphone off while putting the headset on. The lower half of the right headphone's central medallion is a button - indicated by a crossed out microphone icon.
Dec 25, 2009 | Logitech ClearChat Pro USB Headset
Nokia 6070 stays in headset mode w/o headset pulled in
Try restoring factory settings which is in settings
Jul 09, 2009 | Nokia 6070 Cellular Phone
Broken wires on headset
after exposing the enameled wires...light a match and burn the enamel off the wires,.careful not to over burn. ...twist the two ends together or (solder) and viola!
Jun 29, 2008 | Compaq PC Microphone (Black or Beige)...
Microphone problem
Hi!
integrated microphone really wont work on xp. it's either there's njo choice for us or they are still working on it (which i don't believe). Sorry but the system was designed for Windows Vista that's why, there's no driver designated for XP.
Thanks,
Karlox™ :)
Jun 05, 2008 | Compaq Presario 700 470024-192 Notebook
Microphone not working
maybe its a problem with your sound card. Check your microphone settings in Windows.
Dec 11, 2007 | Altec Lansing Stereo Headset with...
Trust Quasar Headset Logo
55 people viewed this question
Top Trust Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Trust Radio Communication Expert? Answer questions, earn points and help others
