Question about Whirlpool Dishwashers
On my Whirlpool Gold the adaptive wash, rinse only, and start/resume lights are on. And the normal, hi temp wash, doorlock, and cancel/drain lights are flashing. Will not run a cycle.
  • Whirlpool Master
  • 15,557 Answers
This could be several things.
1. The heating coil in the bottom of the unit is bad.
2. The pump is plugged up with food.
3. The operating panel is bad.
If you take the kick panel off the front under the door, there should be a technicians service sheet. You can use that sheet to see what the exact problem is.
Posted on Apr 02, 2015
  • Trev72 Apr 02, 2015
    I looked at the sheet, and tried the reset sequence. Nothing happened .
  • Brad Brown Apr 02, 2015
    There are also tests on that sheet that can help you track down what the problem is. Start fresh by turning off the power to the machine and wait a minute and turn it back on. You may have to use the circuit breaker panel to shut it down.
SOURCE: Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Posted on Sep 11, 2008
SOURCE: Whirlpool Gold model GU1200 will not start wash cycle
FYI, for anyone else with the same symptoms. I took mine apart and found that the seal on the motor shaft failed and over time corroded the motor shaft bearing causing it to failed. I ordered full motor assembly from the parts store.
Posted on Mar 21, 2009
  • 132 Answers
SOURCE: Dishwasher does not complete cyele
Sounds like you might need a new Start button.
Posted on Mar 26, 2009
kdrake84
  • 262 Answers
SOURCE: My Whirlpool Gold,quiet partner 3,model
On a "normal wash cycle"
turn all the spray arms at the 12 o'clock position.
Please answer the folling questions.
Will water enter the unit?
After water has stopped entering the unit can you hear the wash cycle start? The wash pump on? and water being sprayed?
Now open the door and see if the spray arms have moved.
Reading what you have posted I just want to make sure that there is never a wash cycle running.
Please post answers.
Thank
Keith
Posted on Mar 01, 2011
  • 202 Answers
SOURCE: The normal wash light is
Hi... you need a new control board ... seen this lots of times
Posted on Mar 29, 2011
Testimonial: "Daddy2keagan knows his stuff."
My washer wont start, I can't get it to cancel or reset. I unplugged for 10 minutes and all lights are still on.
We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 14, 2017 | Whirlpool Gold GU2275XTV Builtin...
How do you get the Codes? for GU1500XTL Dishwasher. Only buttons that work are: Anti Baterial, Pots n Pans, Delay Start, Air Dry, and Cancel. We normally use NORMAL. Need Codes and Wiring Diag. Thanks Walt
I am having the same issue. Did you find a solutions? Looks like websites I've searched talk about resetting the controls by hitting either high temp wash -> airdry -> high temp wash -> air dry OR saniwash -> air dry -> saniwash -> air dry. I'll have to try that tonight.
Oct 20, 2011 | Whirlpool 24 in. GU1500XTLS Stainless...
I have a Whirlpool Gold Quiet Series Plus, Model GU940SCGT3, not working. It ran a cycle, cleaned the dishes, but the water didn't drain and the "CLEAN" light is stuck on. It is now...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Control clean light keeps blinking and dishwasher will not function
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Mar 15, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Washer stopping mid-cycle with no error
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you have drained, unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. F-21 filter blocked.
How abt a nice rating for the free help?
Jan 04, 2009 | Whirlpool GHW9300 Duet Washer
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
Dishwashers Logo
143 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
