Question about Minn Kota Boating
I have a 12 volt 50lb minn kota riptide trolling motor and the shaft moves in and out by at least 1/4". When out it makes noise and has little power. The shaft comes out when I put it in reverse.
    Top Expert:
  • Minn Kota Master
  • 43,109 Answers
Sad to say it will cost more to fix than it is worth .
Posted on Apr 02, 2015
Testimonial: "Thanks for the answer. I'd sorta thought that might be the case."
Minn kota
I have a terrova with i pilot same thing happened found out it was the remote, if thats not it then you will more than likely have to send it in for repair.
May 13, 2014 | Minn Kota Riptide Sp Saltwater 70 Bow...
Minn Kota rip tide st 55 very noisy
is the prop shaft bent you may have busted a magnet in the motor dragging now
Jan 20, 2013 | Minn Kota Riptide St Saltwater 55 Bow...
The turn feature on my remote trolling motor will not work
Maybe the pin is sheated on the prop...or something is caught in it..
check the prop.
Dec 30, 2012 | Minn Kota Riptide St Saltwater 80 Bow...
What sizebattery is recommended for a Minn Kota RT40/s riptide motor
Hi, you can get away with a 70 amp hour deep cycle battery but I generally fit a 100 amp hour deep cycle battery. Hope this helps, regards Phil.
Jun 29, 2011 | Minn Kota Riptide 40 Transom Mount...
Have a minn kota riptide sf 101 thrust 62" shaft.
There is more than the shaft, there is the housing and then everything needs to fit and have correct clearances.....I suggest sell the old one and get a 52 inch new one...
Mar 01, 2011 | Minn Kota Riptide SF 101 Saltwater...
I have a 74LBS thrust trolling motor that hasn't never in my opion worked right, I don't think its wired right to get the proper 24 volts, However I have took it loose and hooked it directly to 2 marine...
Here is a picture of the wire connection for 24 volt. Compare to yours is it correct? If it is, I wish you listed make and model I could of sent you the right picture diagram of you motor. Use this picture as a starting point. Test the wires through the motor testing for 24 volts. Again if I knew make and model I could show you exactly were. Last if voltage is correct all the way through. The motor is the last thing to tear down. If the brushes or armeture is damaged in anyway, or manufactured wrong, it would lead to power loss.
Nov 18, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
I just bought a 74 lb Minn Kota trolling motor that is 24 volt. It is used and has 4 wires (2 black & 2 red) coming from rolling motor. Can you please tell me how the wiring is connected to the...
I have uploaded a image of the wire system. folllow it carefully. the fuses rating should be no more than than thirty amp. go to your local outboard dealer they sell inline breakers that are designed for trolling motors. i prefer them because you don't have to replace them after a overload. you just reset the breaker.de79e02.jpg
Oct 29, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Stuck in gear forward will not shift into any other gear
possiblty a shorted power transister in the speed controller.
Oct 04, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Boating Logo
625 people viewed this question
Top Minn Kota Boating Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Phil Walker
Phil Walker
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
