Question about Maytag Refrigerators
How do I reset or reboot my maytag fridge. I already replaced the control panel. MFI2568AES
  • Maytag Master
  • 5,323 Answers
SOME FRIDGES HAVE A RESET BUTTON IN THE CONTROL BOARD OR ON THE CONTROL BOARD
Posted on Apr 07, 2015
SOURCE: Maytag MFI2568AES Stainless Steel Bottom Freezer
Dear jorge, I had the same problem when my refrigerator was broken. You need to re-program the control panel as follows: 1. First you need the Program Code for your fridge. It is on the plate on the inside of your fridge, on the same plate that has your Model # and Serial # on it. 2. Programming is done with the refrigerator doors open. 3. Press and hold the Door Alarm keypad on the control panel. 4. Then press and hold the Freezer Temperature Down keypad. 5. Then release the Door Alarm keypad and wait 3 seconds. 6. The control pad will then display PE to indicate it's in programming mode. 7. Entry is confirmed by pressing the Freezer Temperature down keypad once more. 8. The control panel will display the current program code. It should be the same one that I asked you to find in Step 1. 9. If the program code is the correct one, exit the programming mode by closing the refrigerator doors. 10. If the program code is not the correct one for your refrigerator, press the Refrigerator Temperature Up or Down to change the value with each keypress. 11. The decimal point indicates the selected digit. Press the Freezer Temperature Up or Down to select the next digit. 12. Once the desired program code is displayed, press and hold the Freezer Temperature down keypad until the program code begins flashing, indicating that it's been saved. 13. Again, when you're done, exiting the program mode is done by closing the refrigerator doors. Hope this helps alot of people out there. I'm not sure what the problem is at Maytag, but they're extremely slow in getting parts shipped for their units. The local Maytag repair people have indicated to me that they are seeing an overwhelming number of Maytag refrigerators needing repairs that are around the one year age range. They say the quality of the new units is terrible.
Posted on Jul 08, 2007
SOURCE: programming code not working
Go to this web page to find the text answer below: http://www.fixya.com/support/t233614-reprogram_hv_board
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 :WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Posted on Oct 26, 2008
SOURCE: need reset code for maytag fridge MFI2266AEU. Just
My sticker is missing. What code do I use?
Posted on Feb 01, 2010
Sea Breeze
  • 4654 Answers
SOURCE: Water to the ice maker has flooded
OK, water continues to flow into ice maker tray and freezer floor correct? Here is a manual Click here=> MFI2568AES I just need to make sure it is not coming from defrost that may be blocked. Is there water spewing and everywhere? Shut main water supply off ASAP. I will assist you but I need you to answer questions as we move along. There are too many ways this can happen to give you a perfect solution. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Feb 24, 2010
sodeep
  • 3267 Answers
SOURCE: Replaced HV board on Maytag MFI2568AES fridge.
increase the thermostat settings to a more cooler temperature
Posted on Dec 28, 2010
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Refrigerator Model Model #MFI2568AES
This a common problem with these units the high voltage in the main control board is the problem, the main control board in the back will need to be replaced. This runs about 250 dollars for the part. You can order it from this link.
http://www.repairclinic.com/Maytag-Refrigerator-Model-MFI2568AES-ID-657261-Parts?n=2
Nov 09, 2013 | Refrigerators
Ge eterna touchpads
I would first pull the plug then reset the breaker then plug the unit back in. If the control panel does not come back on then check the power source by plugging a lamp or radio in where the fridge is plugged in. If they work the you will have to take the back panel off of the fridge and check for loose wires or a loose marrette. If all looks good then unfortunately it is probubally the control that is pooped out and needs to be replaced.
Sep 07, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568aes:none of the keypad controls work. Is it the control board that is no good?
Check the harness up at the top of the door. Remove the cover and be sure everything is plugged in correctly. Sometimes the harness will work loose do to door movement.
Aug 18, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Fridge is plugged in with no water hooked up and it is not cooling in fridge or freezer
In most cases that will be this part=> 67005560 Relay_overload_with_start_capacitor That part is located here=> MFI2568AES Compressor Components and item 12 in photo. I have the Service Manual yet Whirlpool (now owns Maytag)will not let me post it here or on my sites. If you would like to do a ServiceTest you may contact me => Here at top or near bottom of page. Whirlpool did not say I could not share with the customer, Thanks Sea Breeze
MFI2568AES Parts Manual
User Manuals Here=> Whirlpool User Manuals
Feb 16, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Bottom Freezer Fridge 25 cubic ft. Model-MF 12568AES Code- 0302 Serial #- 10040844JN Problem- Control panel not responding and no water and ice through dispenser.
the control panel is a p c board . maytag call's it a jazz board . and will need to be replaced . not a uncommon problem. also the water will work after tempts a stablized . with the new board . one board fits all but has to be programed for your model . this is a job for your appliance tec . the board comes with very good instructions . . if handy with electronics its not hard .. **** hope this helped ..
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
I don't know how to turn on the door panel
I had same issue. The control panel had been set to Sabbath mode. Hold down the "DOOR ALARM" button for 3 seconds. Then lights will turn on on both display windows. Scroll using the + and/or - sign on the left side display until "SAB" is shown. Then scroll using the + or - sign on the right side display until OFF is shown. Finally, hold the "DOOR ALARM" button down again for 3 seconds. All should be good to go!
Aug 29, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
May 25, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerators Logo
990 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
