Question about Danby Microwave Ovens
Microwave wont shut off
Danby microwave runs by itself all of a sudden. open door only way to stop it, close door it starts again no countdown timer unplugged plugged in same thing.
    New Friend:
There is just a malfuction in the circute board go and get it fixed
Posted on Apr 01, 2015
Runs when door is closed,stops when open!Checked the three door switches;all good.The mw is 5 years old so anyone have suggestions as i would be thanking U in advance
It is possible that a relay on the control board has stuck in the closed position. You can try tapping the relays on the main control board and this sometimes breaks them free. It still may be one of the door switches but I would suspect the control board or possibly a stuck start pad on the touch panel.
Apr 24, 2015 | Cuisinart CMW-100 Microwave Oven
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
Unit starts automatically when door is closed
please review this and fix it. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Nov 18, 2013 | GE PSA2200RBB Microwave Oven
Microwave making noise all the time if plugged in & door shut
Sounds like a bad control board. Change it or buy another unit.
Jan 21, 2013 | DeLonghi Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Microwave won't shut off
The door switches are what tells the microwave that the door is opened or closed. If they play up they could be causing your microwave to act strangely.
Mar 25, 2009 | GE Microwave Ovens
Our Microwave keeps running unless we give it a whack!
Hi firstly to see if it is producing energy, buy some 5mm light emitting diodes from an electronics store. cut off the leads close to the plastic body.
place in microwave and put on cook for max 10 secs, if the led's light up you have microwave energy, shut off the oven as soon as they glow otherwise you end up with a mess.
If you have energy then your problem is most probably the door interlock micro switches which after time do not operate properly. let me know the results and we can go further.
Feb 23, 2009 | Danby DMW1153 Microwave Oven
WST3501 Problem
We have had problems like this before. Most likely the smartboard is defective.Check with manufacture to see if there is a recall.You should be able to find them on the web.
Nov 02, 2007 | Microwave Ovens
Microwave Ovens Logo
144 people viewed this question
Top Danby Microwave Ovens Experts
William Miller
William Miller
vince
gbob59
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
