Question about Dewalt D55146 Heavy Duty 412Gallon 200PSI Heavy Duty Hand Carry Compressor with Wheels
The collar on the quick connect coupling seems to be stuck preventing me from being able to connect air hose. It seems to be free enough that i can turn it but i cant push it in to connect the hose.
    President:
  • Dewalt Master
  • 1,383 Answers
If wd40 does not help, just replace the fitting with generic quick connect from Lowes or home depot. Cost is about 4 dollars. Take the hose with you so that you can try the fitting at the store. There are several styles of quick connect. Automotive, industrial and universal. Good luck
Posted on Apr 02, 2015
Is there any disadvantage to a leather collar for my cat?
Cat collars must have a quick release mechanism in case they get stuck on something. Sometimes the collars have an elastic band that can easily snap if caught or you can get collars with an easy open clasp. You should not put a collar on a cat that cannot easily open for risk of strangulation.
Jul 18, 2012 | Cats
Innotek shock collar
I had same problem with an Innotek Bark collar. However after my dog s barking caused shocks the first times he wore it and quickly he changed that behavior. It finally and quickly got to the point that I still used it on him but I never had batteries in it as just wearing the collar was enough to stop his annoying the neighbors. These collars do not have a long lifespan like most electronic goods.
Jul 01, 2012 | Innotek Pets - Others
Ryobi Power drill - Chuck locking button is stuck down. Any suggestions as to how to loosen it gratefully received.
Put the motor in reverse and bump the switch quick. If the spring is not broken, that should release it. There may be some dirt or other debris in the pocket that button engages, so blowing it out with compressed air periodically might be enough to prevent a reccurance.
Jan 29, 2012 | Drills
On Duet Front Loader- Error code F/H. Can see plenty of water coming in so I suspect pressure switch. Is this a common problem? I don't quite understand your pressure switch check procedure in your...
This error code F/H tells that no water entering the machine is detected during the fill step of the wash cycle. It can be due to siphoning, pressure switch not tripping or stuck in the empty position, or the water flow meter is not reading the correct water flow. Make sure that no water is draining out of the drain hose due to siphoning as water fills in and position the end of the hose to prevent such condition.
The pressure switch is stuck and not tripping if after 8 minutes the water flow meter has detected 10.5 gallons of water passing through it but the control has not detected the pressure switch trips. The water valves are then turned off and the error code is flashed. The error code is also flashed if after 30 seconds the water valves are turned on and no water is detected entering the machine due to sticking flow meter pinwheel or the flow meter is not positioned properly.
The flow meter is position sensitive. The pinwheel must be installed vertically. Any canter to it may cause the wheel to stick. Many times the F/H error code pops up only when HOT water passes through the flow meter. The hot water may be softening the hoses on either side of the meter, causing the flow meter to canter. Stuck or cantered pinwheel affects the flow meter's ability to read water flow accurately. Disconnect the hoses from the flow meter then blow air into the inlet to free a possible stuck pinwheel. Replace the flow meter if the pinwheel is totally stuck and cannot be freed.
Check the pressure hose for possible kinks or air leaks if the flow meter pinwheel is positioned vertically and turning freely. Kinks and air leaks in the pressure hose prevents pressure built up in the pressure switch dome and the pressure switch cannot trip. Check the pressure hose including its connections to the pressure switch and the bottom of the tub. Blow air into the pressure hose to clear possible clogs or kinks and check it for air leaks. Also blow air into the pressure switch dome to free a possible pressure switch contacts welded or stuck in the empty position. You should hear the pressure switch clicks if it is tripping. Replace the pressure switch if not tripping and the pressure hose has no kinks or air leaks.
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I can't get the hose to connect to the compressor.
after scewing the fittings on hose & compressor with thead tape (ofcourse) ,simply pull the collar back on the female fitting & incert the male fitting & release the collar .----------these may be called quick connectors but they require a little effert under air pressure.
Jun 03, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
How to replace 2002 pt cruiser starter
2.4L Non-Turbo Engine
Remove or disconnect the following:
Negative battery cable Air cleaner box cover Engine structural collar Starter electrical connectors Starter To install:
  1. Install the starter and torque the bolts to 40 ft. lbs. (54 Nm). Attach the starter electrical connectors.
  2. Install the engine structural collar on models with a automatic transaxle as follows, refer to the illustration for bolt locations:
    1. Place the collar in position and hand tighten the collar to transaxle bolt.
    2. Position the power steering hose support bracket and install the collar to oil pan bolt.
    3. Place the bending strut in place and hand start the bolt.
    4. Install the bolt through the strut and collar and hand tighten.
    5. Place the power steering hose support bracket in position and install and hand tighten the remaining bolts.
    6. Tighten the collar-to-transmission bolts to 75 ft. lbs. (101 Nm).
    7. Install the bolts through the strut and into the block.
    8. Tighten the remaining bolts to 45 ft. lbs. (61 Nm).
  3. Install the engine structural collar on models with a manual transaxle as follows, refer to the illustration for bolt locations:
    3. Position the clutch slave cylinder into position and hand start the bolts.
    4. Tighten bolts (1) to 75 ft. lbs. (101 Nm).
    5. Tighten bolts (2 and 5) to 45 ft. lbs. (61 Nm).
    6. Tighten bolts (3 and 4) to 20 ft. lbs. (28 Nm).
  4. Install the air cleaner box cover and connect the negative battery cable.
2.4L Turbo Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Air cleaner box cover Upper starter bolt by pushing the inner cooler up and out of the way Inner cooler lower hose from the inner cooler Nuts retaining the inner cooler tube Studs retaining the power steering lines Position the power steering lines aside Engine structural collar Starter electrical connectors Starter
To install:
  4. Install or connect the following:
    Power steering lines aside Studs retaining the power steering lines and tighten to 45 ft. lbs. (61 Nm) Nuts retaining the inner cooler tube Inner cooler lower hose to the inner cooler Upper starter bolt by pushing the inner cooler up and out of the way. Tighten to 40 ft. lbs. (54 Nm). Air cleaner box cover Negative battery cable
Jul 03, 2010 | 2002 Chrysler PT Cruiser
Hose comes off of the faucet
A quick easy fix would be to get a hose clamp and tighten it down on the hose to keep it from popping off
Jan 24, 2010 | Kenmore 17252 Free-standing Dishwasher
2-yr old troy-bilt pressure washer with honda gcv160 engine. seems to run well, but when trigger is pulled get full pressure for less than 5 seconds before reducing to house water pressure. when left...
It sounds like an air lock. Try this: With the machine off, connect the hose to the washer and let it run for several minutes to get all of the air out of the hose, and to purge any air out of the pump. Shut off the water, and connect the high pressure hose, but not the gun. Let the water run for several minutes. stretch out the HP hose and make sure that the air is displaced. Shut off the water, connect the gun, and purge as before. Now crank it washer up. As quickly as safe to do so, open the trigger to keep water moving through the washer. It should come up on pressure very quickly. It is better during normal operation to keep water moving through the system. When I am through for a while, I shut down my washer, but leave the trigger depressed to allow the pump to stay full of water, and cool. This prevents further problems when I restart it.
Hope this was useful.
Regards --W/D--
Jul 17, 2009 | Briggs & Stratton Garden
Heater is weak
a couple likely causes:
1: the engines thermostat is stuck open preventing the engine from warming up quickly. If the engine temps read normal (warm) but the heater is still cool, then....
2. the Heater control valve (a valve that prevent hot water flow when you dont want it), may be clogged or malfunctioning. this is typically located on the heater hoses between engine and firewall.
Dec 24, 2008 | 1997 Buick Riviera
How to remove the fan blade ?
080204 FixUp EQ air blog remarks
To remove fan blade you need to obtain a thin strong probe, such as a Scratch Awl for wood, that will fit without binding, into the cruciform spaces around the plastic collar. Gently insert into space of plastic collar and lever against the spring metal retaining clamp; getting started may require a bit of force, so be careful to adjust and gauge your efforts. The process is to move clamp in small increments, one side then the other, up the collar until clamp is free to remove.
The collar will still be tight, so if you can form your hands into a gear puller form with your finger tips between the fan blades under to the solid portion of the fan ring, pushing thumbs against the Spindle and lifting in as quick a jerk as you can manage to get it moving. Once moving it should be removed easily enough.
The electric motors have two bearing surfaces, one front one back. Both need to be addressed.
I like Breakfree or similar that acts like minor solvent / major lubricator with good thermal properties. The solvent aspect helps clean out unwanted particles and/or old dried lube. The new lubrication is heavy enough to hold up for at least a year; so yearly checking should be scheduled.
On other brands with heavier motors, I've tried greases when I've stripped down the motors even further. So far I've discovered a heavier lube can be hard on start up and need more time at slower speeds until unit warms up.
Something like WD40 is good for penetration and flushing, but IMO too light for sustained duty. There is a lot of spinning and heat over a year's time.
I just torn down a couple of F1's. They've been doing well for a couple of years. But with all air filters/ purifiers, they REQUIRE periodic maintenance. [Had my biggest laugh reading complaints about Oreck air filters; people NEVER cleaned them and complained when they failed.]
Yes, all these small electrical motors will eventually need lubrication, I recommend before 2 years, as one of mine had a frozen (lack of lube) motor in that time.
If you get into the back to try to get at the rear bearing, you may find that you might be considering a more thorough cleaning (I noticed a bit of corrosion). If you do and if that means taking more stuff apart to clean, be well advised of the time involved and the number of wires needing displacement, especially the electronic wire connectors at the front to the circuit board.
So, get a digital camera and take clear pictures (and check them!) Before and During take apart as well as a couple of paper notes about wire runs and placement. I have even used paint pens to letter/number info to the unit.
Feb 04, 2008 | Ecoquest Fresh Air Air Purifier
Dewalt D55146 Heavy Duty 412Gallon 200PSI Heavy Duty Hand Carry Compressor with Wheels Logo
321 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
