Question about Dryers
Won't heat. How to get apart to check internal wiring?
  • Dryers Master
  • 5,323 Answers
Its not the wireing u want to check but the heat element and the thermostats
Posted on Apr 02, 2015
Won't heat
There could be a number of different reasons for your drier not to be heating. You could start off with making sure your getting 240v to your drier. Then you could check the lint trap outside your house to make sure its not clogged. If all is good you will now have to take apart the drier and with a ohm meter check several parts. Heating element, burnt wire, limit switches, and a few others depending on the model. If your familiar with troubleshooting you can find a schematic on your drier and go from there. If not I would recommend you having a technician to come and check it.
Oct 26, 2012 | Kenmore Dryers
Tip
Casablanca Table Fan, DOA
If your Casablanca Fan (1928D) Table Fan has stopped working completely, or stopped in the middle of oscillating, it might be the internal AC wire that runs up the middle of the fan base, that is broken internally. First, make sure the fan is not plugged in. You have to take the whole fan apart from the front. Check for continuity on the white and black wires that run to the motor. You may have to pierce the black and white wires with a pin to check them, because they are wired directly into the motor. These two wires have a black jacket covering them that can be pulled off if you find an open wire. Either one of these wires can break internally because of the back and forth movement. Cut the wires close as necessary to the motor to make the splice. Solder and use heat shrink insulation and route the new wire back down through the base and splice them where the original wires were. I used a piece of electrical cord with white and black conductors that was cut off an appliance that was dead. It was the same size as the original so it fit well. Please note, this repair requires electrical and mechanical knowledge. You have to take the whole fan apart to do this repair.
on Apr 21, 2014 | Casablanca Fan (1928D) Table
I have a Westinghouse SB915SJ*00 dishwasher. It runs right through a cycle but does not heat. Any suggestions? Thanks.
Hello
The majority of dishwashers are not connected to hot water from the mains but heat up the water internally using the heating element, located in the tub of the dishwasher, controlled by a thermostat. When the dishwasher has a fault with heating, the program will run but not complete and will show an error code on the display panel. Dishes won't be cleaned properly and the detergent won't dissolve.
If your dishwasher does bring in hot water externally from the mains to check the water is warm and there are no problems with the inlet. If the dishwasher heats internally then it is most likely a faulty heating element or thermostat. A fault like this will usually require a replacement part and a repair, but you can check the heating element with a voltmeter to ensure that it is the cause of the problem before calling out for a service engineer.
Sep 10, 2011 | Dishwashers
DWH B10 F3 - no heat. Stops at rinse and beeps + flashes 3 times
Hello
Sep 10, 2011 | Whirlpool Dishwashers
It won't start and displays E3 fault code. Manual says this is faulty coils? Took apart and cleaned all, looks good. Still has code displayed and won't run. How to clear fault code? Thank You.Jeff
E3 means "unit-abnormal protection to avoid occurence of unit damage."
Manufactures does not recommend that a homeowner try to attempt a repair on a code like this as it indicates possible wiring or internal problems. Have you checked for an internal fuse on the circuit board? I would also check the incoming power to make sure you have the proper voltage. You can also try unplugging the unit, waiting 30 seconds and plug back in to see if the code disappears.
According to A/A brands, if this code appears, shut off device and call authorized service company. I'm just trying to get you some things you can check yourself prior to doing that.
Hope this helps.
Jul 29, 2011 | Home Pride AA-TH 358 Air Conditioner
Hello i have a J5 lincat fryer and the pilot stays alight but the burners won't connect (light) have replaced the thermostat and the thermo couple but still no joy any ideas on this not sure what to do...
Check if there is 500 to 750 millivolts across the thermopile wires; thermopile generates 500 to 750 millivolts if properly heated to energize pilot and main valve solenoids of the gas valve for pilot and main burner operation. If the voltage across the thermopile is good and all wiring connections are ok, I think you have to replace the gas valve.
Regards.
Jun 15, 2011 | Imperial IFS40 Deep Fryer
Dryer won't heat anymore. How do we take apart the dryer to look inside?
Before you take it apart. Check your dryer vent hose, if it is restricted then it won't heat.
Apr 30, 2011 | Dryers
Will not heat
You have a faulty wire or bad heating element, I will bet that it is a wire broken or burned apart. Open the unit and check the wiring from the case to the element and check if it is not severed or burned apart.
Dec 24, 2009 | Masterbuilt ESQ30B Smoker
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity -  - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
Protect message
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Jan 11, 2009 | Samsung HTZ-510 Theater System
Dryers Logo
54 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
