WHAT IS THE PROBLEM IN THIS PRODUCT?
THE WASHING MACHINE DOES NOT SPIN IN ANY OF THE WASHING CICLE.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Pump?
Posted on Apr 13, 2015
My dwd m 12c6 daewoo washing machine will not spin
Blocked drain pump and or drain outlet hose. Check the inside of the pump as well. Daewoo are common to get coins etc stuck in the tub to pump hose and foreign material stuck around the impellor in the pump. If it cant pump out, it wont spin.
Jan 05, 2015 | Daewoo Washing Machines
The machine stop during spin cicle
You might want to check the drive belt of your washer. There might be kinks with its belt and you should straighten it up. Also, check for signs of loose objects such as buttons and coins. These might get stuck in your washer's motor causing a malfunction in its spin cycle. Source(s): http://www.washingmachineadvisor.com
May 16, 2011 | Speed Queen Washing Machines
MY WASHER IS NOT DOING THE SPIN CICLE, DRAINS ALL THE WATER OK, PUMP IS FINE, JUST DOES NOT SPIN
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | LG WFT1071TP Top Load Washer
How do I remove the top of my washer machine to replace the spin cicle switch?
Cut and paste this video to show how to remove the cabinet.
http://www.youtube.com/watch?v=WLPGs2UMUJc&eurl=http%3A%2F%2Fappliancejunk.com%2Fforums%2Findex.php%3Ftopic%3D67.0&feature=player_embedded#t=15
May 11, 2010 | Roper RAS6233KQ Top Load Washer
The machine do not complet the cicle.in the regular cicle, the machine finnish washing but do nt let out the water and the cicle stop at this point
have a look and see if outlet pipe is kinked not allowing water to drain, failing this you may have a blockage in the pump system
Dec 17, 2009 | Washing Machines
Machine does not drain and spin at end of cicle It is a LG top loader washing machine model R852
Your motor clutch is bad. That controls on the motor along with the timer on a washer from going to spin or agitate.
Dec 05, 2009 | LG Washing Machines
The spin bang all over the machine
is it actually spinning or jsut making banging noise. if just noise
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Jan 16, 2008 | KitchenAid KAWS850LE Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
