Question about GE Refrigerators
I have model number PDE18LZRBB. Freezer works fine; refrigerator section will not cool properly.
Previously diagnosed with plugged drain; What can I do to repair this myself. Can't seem to find any good hands on instruction or diagrams. What else do I check? Thanks
  • GE Master
  • 473 Answers
Your problem is usually caused by poor air circulation. The only way the refrig section gets cold is from the fan in the freezer blowing cold air into the refrig section. The fan should be behind the back wall of the freezer and should be running at the same time the complete refrigerator is running. No fan run---no cold in the fresh food section.
Posted on Apr 03, 2015
My Inglis fridge is not working properly..the freezer works fine but the fridge is not cooling
Can you do some testing of the compressor start components for me? If yes the you will need a test meter to test the compressor windings. This way I can see just what parts you may need and I can explain what to do. First look around the fresh food section door for as model number. Send me the model number by posting the model number here on Fixya. Here is a link to Refrigerator Troubleshooting and at the bottom of that page there is a how to test the compressor for a defective start relay. Here is a Refrigerator-Troubleshooting-Guide If you have any questions please ask and I will be glad to assist you, Thanks Sea Breeze
Oct 02, 2012 | Refrigerators
Refrigerator stopped cooling but the freezer still works fine
you should have sent the model number so i could look up your machine,open the freezer door,do you hear the fan blowing in the freezer?if not you have a bad evap fan motor,if the fan is good you could have a bad damper located in the fridge section,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air over into the fridge section,it could just go through an air duct or through a damper,if there is a damper most likely this is your problem or check the back inside wall of the freezer and see if there's any frost on it,you could have a defrost problem or the door could have been left open and the air ducts frose up,also if the freezer is on top you could have a blocked drain in the freezer and the air ducts are iced up,look under the crisper draws to see if any water is under them if so the drain is blocked.these are the things to check,if you send the model number and a little more info i can help you out better
Sep 04, 2012 | Amana Refrigerators
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
Model rb17ka-1al food section not cooling but freezer works fine
That is gonna be a bad fan motor up top OR the drain pluggs up and puddles water between the two sections. The freezer works fine but no cold air can get to the fresh section below. Seen it. Thaw here out and yank out the floorboard of the freezer. Clear the drain and oil the fan motor. No parts needed.
Aug 07, 2011 | Magic Chef Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
I keep getting water in the refigerator. Everything works fine, but the water just drips and drips
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | Haier RRTG21PAA Refrigerator
No Cooling in the Fridge section, freezer is icing
Generally on these models they rely on cold air being pumped fr\om the freezer to the fridge and have a adjusting device to control the flow, you need to locate and check this is free and working properly. Another reason for freezer ice up is a shortage of gas in the unit, this is usually unfixable as the leak can rarely be found as it usually occurs within the cabinet case. Sorry to say it would then be a throw away.
Peter
Jun 03, 2009 | Refrigerators
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
