Question about GE Profile PSB48YSXSS 48" Built-in Side by Side Refrigerator with 29.6 cu. ft. Capacity, 4 Spillproof Glass Shelves, Overhead Evaporator System, ClimateKeeper System, External Ice/Water Dispenser, External Controls, Quick Ice and Wire Slide-out Freezer
How to replace the front display touch pad
Part #wr17x12606
  • GE Master
  • 473 Answers
If I remember right, the touch pad board is just press fit into the dispenser frame. You will need a small thin straight screw driver or similar. I use to use my pocket knife blade. Stoop down low and look up at the very front edge of the control area. The plastic edge you will see is about 1/8 inch thick and a tight seam behind that edge. That is where you insert the screw driver and gently pry the control board away from the refrigerator. Once its loose you will see the wiring that needs unplugged. On some older models there was 1 or 2 little screws holding it on at each end. If you don't see the screws it just pops off as I stated before.
Posted on Apr 03, 2015
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 20, 2010 | Magic Chef Kitchen Ranges
Touch screen not working only allowing me to access one item on the front screen and the inside screen is cut in half
Hi, the problem might be from different areas, like the touch screen or from the flex of the phone.
due to the cut half display,might has affected the touch pad. You will need to replace the cut half screen to see if the screen is attached to the touch pad.
Also the phones touch screen might not be working because there might be a problem with the flex of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
Have a nice day.
Sep 03, 2010 | LG enV Touch VX11000 Cell Phone
Display shows E0 F2 after pressing start and cancel at same time. No other buttons work. Stovetop still works.
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 14, 2010 | Whirlpool GY398LXPS Electric Kitchen Range
Oven is displaying f1-8 error code what is it
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
May 04, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Electric Range.-oven stopped working. Error Code F1 show on electronic display
Hello there:
Here is the 2 most common f1 codes for this oven and what the problem is and what repair procedures that should be taken
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC)
Dec 13, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
The touch pad does not work. It displays menus
HI. this damaged touch pad board should be replaced asap. the board itself is not repairable.
Replacing the board will fix the issue.
Sep 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I am receiving the same error message on the display window
Function key shorted or stuck :
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 12, 2009 | Maytag MER6769 Gemini Electric Kitchen...
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Kenmore Electric Range
F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Feb 15, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
GE Profile PSB48YSXSS 48" Built-in Side by Side Refrigerator with 29.6 cu. ft. Capacity, 4 Spillproof Glass Shelves, Overhead Evaporator System, ClimateKeeper System, External Ice/Water Dispenser, External Controls, Quick Ice and Wire Slide-out Freezer  Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
