Question about Magic Chef Refrigerators
How do I clean the condensate drain on a Magic Chef fridge mod #ctb1521grw
Condensate drain
  • 52 Answers
If not mechanically inclined, call service tech. you could clear by blowing condensed air from drain line outlet, or attempt to disassemble and clear drain from evaporator drain pan
Posted on Apr 02, 2015
Dial with numbers is gone. Is coldest setting clockwise or counterclockwise
Type it into google (model number etc) and look for a pic of temp dial. Either that or turn I one way, check temp then turn other way and check again the write it on with a tipex.
Sep 06, 2015 | Magic Chef Refrigerators
I have a magic chef mod#cdb7000aws1 it starts cleans but dont stop i have to hit cancel then drain can someone help me thanks
pump filter at bottom left front of unit maybe stopped up r bad clean out and try again
Apr 10, 2013 | Refrigerators
Where can I find out where the drain hose is located on my Magic Chef refrigerator?
It should be under the fridge. If you remove the lower acess panel on the back you should see a little tray wich is your drain pan. Mike
Mar 19, 2013 | Magic Chef Refrigerators
Freezer has stoped freezing
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck
Aug 17, 2010 | Magic Chef CTB1821AR Top Freezer...
Magic Chef Fridge not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
709oy
Jul 07, 2010 | Magic Chef CTB1722 Top Freezer...
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic chef fridge RB193A
Which fan is working or are all fans working, condenser clean, hear compressor running ? Let me know.
Apr 22, 2009 | Magic Chef Refrigerators
Ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Mar 06, 2009 | Refrigerators
Magic chef gas/electric rv fridge freezer gets cold but fridge dosn't
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Jul 15, 2008 | Magic Chef Refrigerators
Refrigerators Logo
73 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
