Question about Garden
Is there an adjustment for right hand turns - Garden
    Top Expert:
  • 10,875 Answers
No,your mower is built to take wider right turns so it doesnt damage the mower,use left turns instead
Posted on Apr 01, 2015
  • Dennis Lee Hanks
    Dennis Lee Hanks Apr 02, 2015
    this guy shouldn't be allowed on your site
  •  johnny rebel
    johnny rebel Apr 03, 2015
    wwhy do you say that??,there was no important info in your question,what make model year of lawn mower,so,how is someone supposed to answer"Question about Riding Mowers & Garden Tractors , Is there an adjustment for right hand turns"or are you cadaver?
How to adjust a Quadra jet carberator on a small block Chevy.
Hello, It's been a long time since I have adjusted a Quadra Jet. Start the engine and bring it up to running temperature. Make sure the choke is fully off. At idle , turn the right hand idle mixture screw in until you hear or feel the engine start to miss. Back out the idle mixture screw 1/4 turn. Repeat procedure for the left hand idle mixture screw. Adjust idle speed screw to 800 RPM for auto trans in gear or 700 rpm manual trans in neutral.
Oct 28, 2015 | Cars & Trucks
Can the headlights be adjusted in 2013 Camry
Yes they should be adjustable because people change tyre profiles front to rear and this alters the drive angle.The adjustment screws are in the headlamp housing behind lamps accessed from the hood/ bonnet side.you do need to do this properly so they align together at the legal height for full beam.there is plenty of online information on the correct height for full beam...once you have made sure all Your tyres are at the right pressure....park on level ground ...at least 3 meters from front of a wall ....and at right angles to the wall....measure the height to the centre of headlight to ground .......mark the right light horizontal line for correct height on the wall and make sure you put lights on full beam....they should shine slightly below (say an inch )to the marked the measurement of height of lamp on the vehicle....adjust until the right hand light horizon is an inch below...now mark vertical line to cross centre of reflected light....this will give you a register point to mark where the left light should fall ...this will be exact distance apart as on vehicle and again adjust left until it falls below 1inch of the measured height line of lamp on car......mark distance from right to left light and mark the same height in chalk....then adjust left light to pinpoint marked chalk cross.adjust the beams by turning the spring loaded screws behind the lights.once you are happy check dipped positions....on right hand drive the lights should dip below and left.left hand drive dip below and right.you probably didn't need so much info but ...hey it's free and it saves any misunderstanding.hope this is of help...please vote.thankyou.
Feb 07, 2015 | Cars & Trucks
Adjusment of hand brake on 2003 Kia Carnival
firstly don't just tighten the cable. take the drum off and check the auto adjusters, you can adjust it by hand by turning it a few notches at a time and replacing the drum t check for it binding. I would also check that the handbrake lever inside the drum is operating correctly, (get someone to put the hand break on and off so you can check it0, also when the hand break is right off, the lever should be right back and not half way, if it is not right back then slacken the cable of until it is. (this is what can stop it from self adjusting too) when you have done this to both wheels and replaced the drums check the number of notches the handbrake lever is coming up. If it is too many, then you need to re adjust the cable just enough to take the slack out of it, this should be now fixed but double check that your wheels are not binding. Another point is if your brake shoes are worn down replace them first. if they have any fluid on them from any leak on the wheel cylinders replace the cylinders, bleed the brakes and replace the shoes.
Oct 26, 2014 | Kia Carnival Cars & Trucks
I have a yamaha 1981 pasola scooter and i sometimes starts but sometiimes doesnt. i.bought a ignition coil but it not that. what is the lil blak box that the coil wire connects to? cos thats the problem...
Instructions
  1. Spark Plug and Sensors
    • 1 Park the motorcycle on its center stand. Remove the spark plug-wire cap from the plug by hand. Loosen and remove the spark plug from the cylinder head with a spark plug wrench.
    • 2 Gap the spark plug to 0.026 inches with a spark plug gap gauge. Reinstall the plug tightly in the cylinder head with the plug wrench. Reattach the plug-wire cap by hand.
    • 3 Detach the wire lead at the fuel sensor on the right side of the cylinder head by hand. Loosen and remove the sensor with a metric wrench. Clean the inner end of the sensor with spray cleaner. Reinstall the sensor securely with the wrench. Reattach the wire lead.
    • 4 Detach the wire lead at the exhaust sensor at the underside of the muffler by hand. Loosen and remove the sensor with the metric wrench. Clean the inner end of the sensor with spray cleaner and reinstall the sensor securely. Reattach the wire lead.
    Throttle and Carburetor
    • 5 Take a position where you can observe the throttle linkage at the left side of the carburetor. Twist the throttle grip at the handlebars slowly as you observe the action of the linkage.
    • 6 Tighten the cable adjuster at the top of the carburetor with a metric wrench in small increments so the linkage responds immediately as you open the throttle.
    • 7 Start the engine and allow it to warm up for three minutes. Locate the smaller idle-adjustment screw and the larger fuel-air adjustment screw at the right side of the carburetor. Turn the idle-adjustment screw to the right one full turn with a screwdriver.
    • 8 Turn the fuel-air adjustment screw to the right or left with a screwdriver as you listen to the engine's speed. Turning it too far either way slows the engine's speed. Find the point where the engine idles at the fastest speed.
    • 9 Allow the engine to idle. Turn the idle-adjustment screw to the left one full turn.
Jan 14, 2013 | Motorcycles
I cant get the rear brake drums off ,Icant get the adjusters to back off
are you absolutely certain you are backing them off??? try going the other direction ... I believe one is right hand and the other is left hand ...
If they are backed off ... tap the rim of the hub with hammer --- be gentle ---
May 01, 2010 | 1994 Ford Taurus
Title: Treadmill Belt Problem
determine which side is off centered
If the tread is migrating from the left you need to adjust the tension adjustment on the right and side of the roller and make it tighter
Most adjustments are made by turning a set screw that moves the idler roller ( the roller that is at the end of the tread mill which is where you first get on)
TO ADJUST:
1 TURN THE POWER OFF AND UNPLUG AT WALL OUTLET
2 Locate the adjustment screw( remember you will adjust the side opposite the migration to tighten the roller)
3 manually force the treadmill belt over toward the proper path( I do this by taking my hand and sliding my fingers under the belt and lift the belt as I hand roll it
4 Turn the adjustment screw counter clockwise one revolution
5 plug in then turn on and see if it stays in place
6 Keep repeating the process ( steps 1,2,3,and 4 )
Jan 06, 2009 | Nordic Track NordicTrack Treadmill, A2550
Chimes are nine minutes slow
Take the minute hand off and turn hand over. There is a brass bushing that attaches to the aluminum hand. Take a small screw driver and place in the square hole of the brass bushing. Turn either direction and test on the minute post of the clock. Keep adjusting until the clock chimes right on the 1/4 hour position. Make sure to put the hand back on the right 1/4 hour.
Nov 15, 2008 | Seiko Mantel Clock
Casio watch
Press MODE until you reach H-S (e.g. A 11:00 with seconds on top)
Press and hold ADJUST for 3 seconds until H-S blinks
Press and hold SEARCH for every movement; you may wanna press LIGHT so the hands will move freely. Press ADJUST again to when desired time was reached
Oct 21, 2008 | Casio Watches
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
