Question about Banks Power Pack System 49481 Ford 6.8L Motorhome A 1997-03
Engine lost power in 82 degree weather ,motor home pulling a car?
My 2012 Kia Sedona has a rough idol and wants to stop running at stop signs. The check engine light come on. It is about -30 degrees outside could that be the issue.
emissions tend to freeze up in cold weather.. some folks block the extremely cold air up front with a disposable cardboard sheet.. this allows the motor to run warmer..you may need to do this..some cars have a space betweenthe radiator and the ac condenser to slide a sheet in there..otherwise it goes in front of the grille..
Jan 06, 2014 | 2012 Kia Sedona LX Passenger Minivan 3.5L...
Check eng light came on eng stalled it was 98 degrees outside
You'll have to figure out if it is a fuel or ignition problem.
Is the check engine light on before the engine dies ?
It can run in 125 degree temp so there is a problem that may have been made worse by the 98 degree weather.
My first guess would be the idle control motor or valve if it has one.
Jun 29, 2012 | 2004 Buick Rainier
How many hours do you need to let the intex krystal clear salt water system run on an about 6000lb pool?
If you refering to 6000gals it needs to operate 4 hours in 66 degree weather, 5 hours in 82 degree weather, 6 hours in 97 degree weather, and 7 hours in anything than 97 degree weather.
Jul 22, 2011 | Intex Automatic Salt Water System for ...
How many thermoststs does the nissan nomad have
1 this being the specifications on it
Features & Benefits Quality Controlled Factory Calibration Assures Accuracy Of Opening & Closing, Regardless Of Pressure Changes. Positive Piston Heat Motor Provides Accurate Temperature Control. Sturdy Metal Construction Throughout. Attributes Depth from Flange : .82"
Design : Offset
Flange Diameter : 2.125"
Height from Flange : .91"
Jiggle Pin : Yes
Temperature Range : 195 Deg
Warranty Limited Lifetime-See Manufacturers Written Policy
Warranty PDF
Material Safety Data Sheet (MSDS) There is no MSDS for this item Application Information: 1990 Nissan Van Engines : 2.4 L 2389 CC L4 SOHC
Comments: 195 Degrees;Alternate Temperature
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Feb 27, 2011 | 1990 Nissan Minivan
My truck had been running fine, got up this
it sounds like your starter relay its located inside the engine compartment fuse and relay box .good luck
Oct 23, 2009 | 2006 Ford Explorer
Engine stalling in stop & go traffic
sound like to me you have a clogged catalytic converter
Apr 27, 2009 | 2001 Chevrolet Blazer
Having sharp Photo copy, Model-AR121. It is not working. Pls. provide me service center.
Sharp AR-121 code
CC Original not detected E1 00 Lost communication with the Sorter 10 Lost communication with the Sorter 11 ASIC error 12 Image Processing Unit error 13 ROM error 14 NVRAM error 15 Page memory fault 16 SIMM not present or installed incorectly 17 Page rotation error in RAM 80 Electronic sort board error 81 82 84 88 E7 03 Lens position error 04 White level calibration error 05 Black level calibration error 12 CCD calibration error F1 06 Shift sort motor overloaded F5 02 Exposure lamp blown F6 00 Fax board problems 10 80 81 82 84 88 F9 00 Printer board problems 10 80 81 82 84 88 H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded 10 Separation motor overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error U2 04 EPROM error 11 Main counter error 12 EPROM error U3 29 Mirror position error U9 00 Op panel problem 81 82 84 88 U95 Firmware error
Apr 08, 2009 | Sharp Office Equipment & Supplies
Reduced Power, Emissions Light is on
when weather warms up a bit run engine at 3500rpm and leave it for about 10mins this should clear the cat out,if the cat runs cold it will clog up reducing the power of the engine
Jan 15, 2009 | 2005 Chevrolet Colorado
Lost all power to the car
loose or dirty battery connections...check voltage of battery
Dec 24, 2008 | 1999 Toyota Sienna
Banks Power Pack System 49481 Ford 6.8L Motorhome A 1997-03 Logo
575 people viewed this question
Top Banks Power Crafts & Hobbies Experts
Debbie
ray gallant
Are you a Banks Power Craft and Hobby Expert? Answer questions, earn points and help others
