Question about Casio Te- 1500 Cash Register Therm Print 30 Keys Lcd Disply
How do I change the tax code - Casio Te- 1500 Cash Register Therm Print 30 Keys Lcd Disply
HOW DO I CHANGE MY TAXES RATE?
Please clarify the question. If you mean tax withholding rate, change the number of exemptions on your W-2. That won't change your tax liability at the end of the year, but will change your take home pay. If you mean actual tax rate, then you need to change the amount or source of your income, or change your tax deductions. Regarding source, I mean earned income vs investment income.
Jan 22, 2015 | Office Equipment & Supplies
I have set the tax amount, but can't change the departments for tax an dnon tax
In the department programming section, there should be a setting to turn on each tax (tax1, tax2 etc). Turn on or off the tax that you just set the rate for.
Feb 17, 2012 | Casio Parts Cash Register PC Desktop
How do you change the tax #2 ??? tax #1 is 5% and tax #2 is 7,5% but i want to change tax #2 for 8,5%, how should i proceed??
i have cash reg. gold 2100 , and i programed the cash reg for (7.5 % to 8.5% ), by changing the 1508030 tax shift 2 to 1509030 tax shift 2 while the key is on program position.
the steps from beginning :
first: put the key on prog position.
2nd: enter 1505000 then press tax shift 1 ( 5%)
3rd : enter 1509030 then press tax shift 2 ( 8.5 %)
4th : enter 037000000 dep 1 ( tax able )
5th : enter 037000000 dep 2 ( tax able )
6th: enter 037000000 dep 3 ( tax able )
7th: press # / no sale .
put the key to reg position and try it . good luck and happy new year.
p.s. for no tax dept dont enter any thing .
Jan 01, 2011 | Casio Parts Cash Register PC Desktop
Changing Tax Rate for July 1
LOG ON TO THIS WEBSITE
http://www.casio.com/home/
GO TO TO SUPPORT AND THEN FROM THERE ITS AS EASY AS PIE
Jun 28, 2009 | Casio Parts Cash Register PC Desktop
Programming sales tax
You're right, the manual is terrible but I think I got it worked out...
Turn to PGM mode.
  • Press 3 then subtotal button.
  • Press subtotal button again.
  • Then endter tax rate (if even enter two digits 05 for 5%, if more enter 4 digits like 5.75 *5+.+7+5 for 5.75%) and press ca/amt tend button
  • Press 0 and press ca/amt tend button
  • Press 0125 and press ca/amt tend button *this is for rounding/tax table code not positive on this one but looks like the right entry for "add on" tax
  • Press sub total button
This should change your tax
Apr 07, 2009 | Casio TK 6000L Cash Register
Change the tax rate on calculator on MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
Mar 23, 2009 | Casio Office Equipment & Supplies
Te-2200 can't calculate tax-on-tax
Hi.
Have you set your departments or PLUs to use both taxes?
Dec 11, 2008 | Casio Parts Cash Register PC Desktop
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
IN need here
what type of cash register do you have?
what type of tax system do you have?
Apr 01, 2008 | Casio Parts Cash Register PC Desktop
Casio Te- 1500 Cash Register Therm Print 30 Keys Lcd Disply Logo
59 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
