Question about Samsung UN Televison & Video
HOW DO I UPDATE MY SAMSUNG LED TV FIRMWARE MODEL NUMBER UE46B8000XWXXU
I CAN'T SEEM TO GET ANY SOFTWARE UPDATES FOR THE FIRMWARE FOR MY TV MODEL UE46B8000XWXXU AND ANY INTERNET CONNECTION. CAN YOU HELP TELL ME WHAT I IS THE NECESSARY STEPS I SHOULD TRY NEXT PLEASE IF POSSIBLE.
    Scholar:
  • 190 Answers
Try opening your menu options and search for "updates" Usually when you set your TV for the first time it usually guides you to do this firmware update. Try acting like your are setting up your TV for the first time and maybe it will have a option for this.
Posted on Apr 03, 2015
Is there update firmware for LF320FX4F Made In Oct. 2013
According to the product support page, Funai has not released any new firmware for the LF320FX4F. Go to http://funaiamerica.com/product/product.php?id=880 and click on the Downloads tab. You can also check for updates from the Support Downloads page, http://funaiamerica.com/support/download.php , by entering the TV model number.
I hope this helps.
Aug 23, 2016 | Funai 32" LED 720p 60Hz TV | LF320FX4F
Tip
Hitachi 22HXJ06U stanby LED flashing red and blue.
Recently first thing in the morning I've found my tv power on / standby LED is flashing red and blue. The tv does not seem to respond to the remote...but after pressing remote on key the tv will eventually come on about 3 to 5 minutes afterwards. It would seem that the tv does an auto update during the early hours and then on next switch on it completes the update...during which time it seems that it has not turned on. To prevent this annoying behaviour you can disable the automatic software updates in the settings menu... see pdf user manual at https//estadoc.hitachi.eu/servlet/FileViewer?DocumentName=22%20IB.pdf see page 23 about software upgrade. In the settings options you can disable the auto upgrade. Occasoinally I expect it would be advisable to either enable the auto update for a day or two or do manual update.
on May 02, 2015 | Televison & Video
My Sony Bravia TV will not turn on. the power light flashes red 7 times then stops for 4 seconds then repeats
System Error:
  • If a Red LED is blinking and the TV is not working properly it means that the TV has detected an issue or problem. Most Red LED blink conditions require service. The meaning of the blink codes differs between TV models, but the following steps may resolve user serviceable errors related to heat, temporary conditions, or software updates:
    NOTE: 8 Times Blink - For certain models, a special reset procedure is needed if the Red LED on the front of the TV is blinking 8 times and then repeats. This is a model-specific issue that may be resolved by following these steps (please check the answer to be sure your model is included).
    For other TV models or other Red LED blink codes:
    1. Turn the TV off and back on. If the TV will not respond to the remote or the power button, or if that does not fix the issue, unplug the TV. For a Projection TV or Projector , leave it off for 3 minutes. For other TVs leave it off for 1 minute. Plug the TV it back in and turn it on.
      NOTES:
        • If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
        • Projection TVs and projectors need to cool down before they will turn on again. You may need to wait several minutes before these will turn back on.
    2. Clean any vents/slots in the TV cabinet and make sure there is room for air to circulate around the cabinet of the TV.
    3. Some Sony TVs have a media box (tuner) and separate display. If you have one of these TVs, check to make sure the cable between the media box and the display is securely connected.
    4. For Projection TVs and Projectors, make sure that the cover/door for the lamp is closed and secure.
    5. If the TV can be operated at all, check to see if a software update is available.
      • If your TV is connected to the Internet, press the Home or Menu button on the remote to get into the setting menus. The Software Update option is usually found under theProduct Support or Contact Sony menu.
      • NOTE: For a limited number of Internet-capable models, the only option is to turn onAutomatic Software Updates and allow the TV to update on its own. If you only have this option, make sure it is set to On. Automatic updates are only downloaded when the TV is in standby mode (turned off with the remote but not unplugged). Normally this download will happen overnight but may take up to 24 hours.
      • Software and driver updates for your Sony product are available online. You can check to see if a software (firmware) update is available for your television. Steps to install will be included if an update is available.
      • Older CRT TV's and TV's that cannot be connected to the Internet do not have an option to check for a software update or may not capable of being updated.
  • If these options do not resolve the issue, the problem is most likely related to an internal component that must be replaced and service will be required.RF
Mar 04, 2015 | Sony BRAVIA Televison & Video
How do Update my Samsung smart TV?
Please post a model number for better results and help. If you have a smart TV and it is set up to you wireless internet you can get updates there if not you can go to www.samsung.com and put in your model number under support and it will tell you if there are any firmware updates for your TV. If there is you can download the file to a flash drive from a computer and then plug it into the USB slot on your TV and then go into the menu and find the software update in your menu and select it and the TV will see if the firmware you downloaded is newer then the version already on your TV if so it will ask you if you want to download it you just say yes and wait until it is completely done then the TV will turn off then back on by itself and your done, remove the flash drive and enjoy your Samsung TV.
Jan 26, 2015 | Samsung Televison & Video
Need update for 42inch flat panel tv
What update?
The likelihood of a firmware update for a TV is beyond calculation. These tvs are churned out like toys until the next season's toys are ready to make. The old moldels are forgotten and NO money is spent on updates or spare parts.
Apr 13, 2014 | Samsung Un40c5000 40 1080p Led Tv...
Where do i get updates for my 43"samsung tv plasma series 4+
u can get the latest firmware direct from samsung.com and the go to http://www.samsung.com/uk/support/download/supportDownload and type your model no hope this helps thanks john
Sep 06, 2012 | Samsung PS43E450 43" PLASMA TV FOR 110-240...
Can't seem to find a firmware update for my uncle's Sony Bravia KDL-40s 2000. As usual Sony's support site isn't very helpful. I have two Samsung HD LCD's that are less than a year old and they have...
The firmaware update is made because they found problems out in the field due to badly writen or not properly tested before it was released to the production line.
Dec 05, 2009 | Televison & Video
My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
Oct 20, 2008 | Office Equipment & Supplies
Televison & Video Logo
292 people viewed this question
Jerry Greenberg
Jerry Greenberg
