SOURCE: DirecTV RC64R RF Remote control
Actually, you can go into the system settings by choosing "Parental, Fav's & Setup" then choose "system setup" then choose "remote" the IR/RF setup. Change it to IR and follow the instructions. Once I did that my remote worked on my DirecTV DVD HR22-100
SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
SOURCE: garage door remote control signal problem
On the rear of the motor unit just to the left of all those white wires you will find a small LED. Random flashing is normal but if it is flashing rapidly it shows some type of interference. If this isn't happening then the most common thing is a logic board going bad.
SOURCE: My remote control will not turn the fireplace on,
Clean the sensor on the unit, make sure no dust or ash on it. good luck
SOURCE: intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
