Question about Home
Bathtek shower room 9007 won't switch on
Control panel receiving power but will not switch on?
2 Suggested Answers
  • 80 Answers
SOURCE: does anyone have fitting insructions for a steam
Got to this site and download pdf file for installation.
Bathtek-knaresborough.com/steam_shower_9007htm
Hope this helps.
Posted on Aug 21, 2009
I got a receiver and transmitter so I can use my sky in my room. I bought a new samung tv but for some reason I can't change it to av help please
Call the store where you got the tv from. If it won,t switch over there is prprobally a problem with the tv.
Oct 05, 2012 | Televison & Video
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
My creda shower 8500dl won't shut off water keeps
Switch off the power at the main switchbox!
Unscrew the shower cover to reveal the main valve/switch assembly (green in my case)
On the green valve you can line up the bit that moves to select power settings and remove it
Undo the two screws holding the outer switch frame and lift it off
Undo the two screws holding the valve body in.
Remove the valve body, underneath you will find an ordinary tap washer - probably split
Replace the washer - I didnt have an exact match in my toolbox but drilled the middle out of a large tap washer to match
Reassemble..
Aug 10, 2011 | Home
The 'boost' button on my aqualisa digital shower won't switch off. It comes on when I press the shower on (without actually pressing the boost button) and when I press the boost button to try...
Good Morning drlesleyanne. The issue you describe will down to the PCB inside the push button controller. If this does not send the correct signal to the processor box it can cause the unit to 'fail safe' and this is why the unit needs a power reboot. The remedy to this is to replace the push button control itself and once installed should allow the shower to work correctly again. All our digital products have five year guarantees, so you can always call our Customer Service line on 01959 560010 and they will replace this for free.
Kind Regards,
The Aqualisa Team
Jul 29, 2011 | Home
Does anyone have fitting insructions for a steam shower bath enclosure the model number is 9007
Hope this helps.
Mar 08, 2009 | Home
NewTeam Diva T shower - replacement parts
what parts are you looking for? You can call UK Bath Rooms at 0845-200-8527
Feb 03, 2009 | Home
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Home Logo
49 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
