Question about Boating
What is the correct spark plug for this motor ?
  • 3,519 Answers
Hi Anonymouse:
We need a hint.
What kind of motor is it?
Posted on Apr 02, 2015
2000 Dae Woo lanos 1.5L have a DTC code P0304
PO304 is a cylinder misfire on #3 cylinder-- IF-- the code is correct
Nothing to do with gas quality
Doubt a Spark plug is bad
If the Plugs have been in the motor over 3 years,change them
Plug Wire or Ignition Module,whatever you have,would be more
likely
Go with new spark plugs,new ignition wires & front oxygen sensors
Sep 18, 2014 | Cars & Trucks
2004 mercury 150hp,v6,2stroke,spark plug gap
Good Morning Joe,
Please Send Serial No Of Your Motor So I Can Give You Correct Spark Plug For That Engine.
There Are Two Different Plugs Used On Different Models and The Engine Won;t Run Correctly If The Wrong Plug Is Used.
Cheers
Gordon
Apr 08, 2014 | Boating
Sears tractor cuts out while cutting grass like somebody turns the key off
Could be a failing ignition coil,i have seen a tractor start right up and runs,until the coil heats up from the motor. When this happens the motor dies,do to the coil not producing spark to the spark plug. You didn't mention if the tractor's motor was restarted right after it quit running or was it left until later when you attempted to restart the motor allowing the motor to cool. However,how old is the spark plug? If the spark plug is old,the plug will start failing,do to heat also. I would try a new right type spark plug,make sure the gap is set correctly according to your Owner's Manual. I have found that the gap on some new plugs,not set correctly,when it comes right out of the box. You can check the plug,by turning the motor by hand to see if there is a spark,turn on the ignition switch first(DO NOT USE THE START POSITION) when doing this,the tractor just might crank over,will not start if the plug is out.(But your hand could be injured). Check for a bright spark,if there is one,install the plug then try starting the tractor,in the start position. If you,have checked,what i suggested and everything is good-to-go. The tractor should start and run,like a new tractor. One more suggestion,check the fuel filter,while your down,this maybe or maybe not be the problem,doesn't hurt to check it. Sincerely,Brad Locke. DTD. 12/03/15
Sep 06, 2013 | Sears Garden
After replacing spark plugs motor idles or seems out of timing
check to see if you put spark plug wires on correct plugs . If fireing order is correct check for a cracked or miss gapped spark plug
Jul 30, 2013 | 2003 Ford Focus
Tools in replacing 1996 honda odyssey spark plugs
the only specialty tool your should need is a spark plug socket and an extension for the ratcheting wrench.
Other than that, metric wrenches and sockets should work just great.
Jul 06, 2012 | Honda Odyssey Cars & Trucks
2004 lancer won't sart
have you got the timing set correct ,and did you fit the timing belt with all the timing marks lined up ,etc , if there correct ,check for spark ,by pulling off a spark plug lead and fitting an old plug into the lead ,then crank the motor ,dont hold the plug with your hand ,use insulted pliers ,if you have spark, ,if no spark check coil wiring ,coil, crank angle sensor,
Jun 08, 2012 | Cars & Trucks
The starter motor wouldn't turn over.. so.. pulled the carbs as a unit.. pulled the starter.. then buffed the commutator... and voila.. the starter motor now works great.. however.. now that I've gotten...
I did a Suzuki 550 carburetor over haul 10 years ago and had 3 of the 4 intake manifolds crack or separate. I would start by closely inspecting the manifolds. Have you tried draining a carburetor bowl to see if it is full of gas? If the vacuum line to the fuel petcock is not hooked up correctly you could just have fuel starvation. You can hold a spark plug to a cylinder head and turn the motor over to see if you have spark. Correct amount of fuel, correct amount of air, and spark is what you need.
Sep 21, 2010 | 1980 Suzuki Gs 550 L
How do I change the spark plugs?
Engine off
Remove one spark plug wire / using correct size spark plug wrench with / rubber boot designed for spark plugs (deep well socket with rubber boot) remove (1) spark plug / gap new replacement spark plug to specs / install replacement spark plug by hand into head of engine /finger tight /using spark plug socket and rachet finish tighting spark plug / tighten just beyond snug being careful to not over tighten and breaking spark plug ..if in doubt about the proper tighting consult motor manual for torque specs. use torque specs in conjunction with appropiate torque wrench . Re-install removed spark plug wire ...proceed to remaining spark plugs doing one at a time until completed.
Jan 09, 2010 | 2004 Chevrolet Malibu
Honda motor has no spark.
try cleaning the spark plug with petrol. take it out using the correct spark plug spanner, dip it in petrol and light it with a cigarette lighter. give it a thorough wipe with a rag replace it with the spanner. if that dont work. try getting a new spark plug
Nov 03, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Ceramic spark plug failuer
no it is not a common problem just make sure you have the correct plugs for that car
Sep 25, 2009 | 2002 Nissan Altima
Boating Logo
62 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
