Question about Onkyo Ht R530 Receiver 7.1 Surround Sound System Receiver 7 Speakers Remote
Only plays through one front speaker when in video mode.i've tried v-1 v-2 and v-3. i'm using optical for audio
  • Official Brand Answer
  • 333 Answers
Hi Richard, please make sure that the source has been assigned to the optical connection via the setup menu or you can select the source and then press the digital input button until the display shows the optical connection where the physical connection was made on the back of the Onkyo, Thanks, JT
Posted on Sep 10, 2015
3 Suggested Answers
  • 4234 Answers
SOURCE: Dialog track not playing for a 5.1 DVD
Unfortunately without "surround" processing, the center speaker will not work at all. It sounds like there is a problem with the center channel amp which is part of the receiver. This should be a single amp IC attached to the heatsink. There should be a "test" moe that will send white noise to each speaker in sequence. Try that. If that results in no sound to the center, it pretty much concludes that the center amp needs to be repaired. The part cost for this should be around $25.
Dan
Posted on Dec 04, 2008
dedlyvirus
  • 11 Answers
SOURCE: hi i can't get any sound thru my speakers. I have
first: make sure you have the audio output setting on the ps3 set to digital optical output
second: make sure you select whatever the optical input is assigned as, probably dvd. i think there is a button on the front of the receiver that says digital input, make sure you hit that. A little light on the front screen of the receiver will say digital.
Posted on Oct 16, 2011
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
Receiver says center channel unavailable
It may be the surround mode you are in. Some modes do not use the center channel. Try changing to a pro logic mode, these will almost always use the center
Jan 23, 2013 | Onkyo TX-SR304 Receiver
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
Apple tv to optical audio on avr 1601
You need to assign the optical input to the video input you are using. It's under the 'Input Setup' menu.
Or use HDMI, it will output the audio thru the HDMI connection. Once again assign the input under the Input Setup menu (press the Menu button on remote to access setup menus)
Nov 19, 2011 | Denon AVR-1601 Receiver
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
I DO NOT HAVE ANY IDEA WHAT IS THE USE OF THIS PRODUCT AND HOW TO CONNECT IT.PLEASE,IF YOU CAN HELP ME AND GIVE ME A DESSCRIPTION OF HOW TO USE IT AND CONNECT IT,I'LL APPRECIATE THIS.. THANK YOU
this unit will play your television sound through a set of 5 different speakers enabling you to have 5 seperate sounds from 5 seperate speakers simultaneously, giving you the sensation that you are in the middle of what you are watching. you will need a set of 5 surround sound speakers and a sub woofer (speaker that plays low frequency sounds so the speakers dont have to) the video and audio come into the phillips receiver and then the video will be sent to the television and the sound to the speakers.
Usually send the video signal from your cable box to the video 1 (video in) port on the phillips receiver audio signal from the cable box to the audio in on the receiver under video 1 --video cable will go in a yellow port. audio will be a fiber optic audio cable you can buy at any electronics store and go into the audio in port for Video 1. then connect a cable to the video out port for Video 1 and into the back of your television on any of the video in ports.
Nov 29, 2009 | Philips FR965DHT Receiver
I can only get 2.1 sound from my Playstation3
optical cable connection in tv is only input and same in receiver it is both inputs.you need to find the right encoding in your receiver mode/set-up
Apr 21, 2009 | Sony DAV-HDX500 System
We have a Denon AVR Surround Sound receiver, a Samsung HDTV, an XBox 360, an ASD-3W Denon Ipod Dock and Klipswitch speakers with a subwoofer, center channel and too bookshelf speakers. We need help...
HDMI input connect as follows:
1. Connect an HDMI cable from the Cable box to the TV/CBL HDMI input on the Denon.
2. Connect an HDMI cable from the Xbox to the DVD/HDP input on the Denon.
3. Connect an HDMI cable from the HDMI out-put on the Denon to an input on the Samsung.
You don’t have to use the optical output from these to devices since the HDMI cable allows for the transfer of both audio and video, if you have them extra use them in addition to the HDMI cable and last,
4. On front of denon after you setup and assign your optical connections, if you use them, once you select TV/CBL or DVD/HDP as a source, press the input mode button to select auto
Jan 08, 2009 | Denon AVR588 Receiver
Onkyo Ht R530 Receiver 7.1 Surround Sound System Receiver 7 Speakers Remote Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
