Question about Kitchen Ranges
The glass gets very dirty - Kitchen Ranges
    Top Expert:
  • 10,875 Answers
Use a glasstop stove cleaning solution
Posted on Apr 01, 2015
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
My scanned image has many thin coloured lines ruinning through it. It is not a dirty glass issue as the help page suggests
The mirrors in the optical system under the glass may be dirty or the lens near the CCD (charge coupled device) may also be dirty. This can happen over time. Dust gets in there and can cause this.
Dec 06, 2010 | HP ScanJet 3970 Flatbed Scanner
Dirty cutlery, glass wear getting a dull film
WHAT IS THE TEMPERATURE OF YOUR WATER, SHOULD BE AROUND 140 DEGREES.
Feb 26, 2010 | Dishwashers
Platen glass dirty clean platen glass
user mode
common settings
additional functions
13. adf dirty error
display(default) / do not display
Sep 18, 2009 | Canon imageRUNNER 1023iF Black and White...
Receiver end of faxes shows vertical black line. I changed drum and toner also cleaned glass scanner. I do not have a glass flatbed scanner only an automatic feeder.
The cause of this problem is usually a dirty scanning glass (there might be ink or white out on the glass). Check the glass really closely or the cause could be dirty optics or a bad CCD board. There are mirrors underneath the scanning glass. Dirty optics can cause lines when faxing or copying. If you can not access these mirrors, they would have to cleaned by a technician.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Sep 08, 2009 | Brother MFC 4350 All-In-One Laser Printer
Dirty streaks between glass front
depends on type of unit,but most separate by opening oven door and removing the screws around the perimeter of the door, be careful reinstalling as to get inner and outer glass re-positioned right along with insulation,this is especially critical because the outer glass can't withstand self-clean temps and will break
Aug 22, 2009 | Ovens
Black streaks on copy
This can be anything from something on the glass to charge corona dirty, laser dirty, drum or blade or fuser rollers need to be replaced. For the average person, the best you can do yourself is to make sure glass is clean. Question..... do you get this line if you're printing also? If yes then that would eliminate the glass and has to be something inside. If no, then look very carefully at the glass and long skinny glass on top, if it has that, for white out or something on the glass. Sometimes you won't even see spot unless you look at just the right angle. Good luck. Please rate this if it helps.
Jul 03, 2009 | Sharp SF 2020 Copier
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Dirty Glass on Lexmark X5100
suggest you bring your printer to the nearest authorised repair center and have them do the cleaning...it will save you cost
Mar 23, 2008 | Lexmark X5150 All-In-One InkJet Printer
Dirty glass
Taking that glass apart requires removal of almost all exterior covers. Not recommended to users without technical training. Any Samsung copier service center should be able to do it, since the unit is really made by Samsung as model SCX-4720f/fn.
Sep 19, 2007 | Xerox WorkCenter PE120i All-In-One Laser...
Kitchen Ranges Logo
49 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
