Question about Garden
Belt diagram for toro416 42 inch rear discharge cutter deck
    Sergeant:
    Champion:
  • 495 Answers
Diagram for belt routing should be visible under tractor at running board area
Posted on Apr 02, 2015
mowerman1857
  • 389 Answers
SOURCE: I need a belt diagram for Craftsman LT 2000 42
Look under the "running boards" Sears(AYP) sometimes put them under there. If not, go to www3.sears.com, type in your 917.xxxxxx model number and the pictures will show you an exploded view of the belt configurations
Posted on Sep 14, 2009
  • 133 Answers
SOURCE: need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
Posted on Jul 29, 2009
  • 6 Answers
SOURCE: need diagram for deck belt
Try http://www.rcpwparts.com/parts.asp
Posted on Apr 22, 2009
  • 376 Answers
SOURCE: 46 inch cub cadet mowing deck
Go to... http://www.partstree.com/parts/ Click on the Cub Cadet logo then enter your model number. All the diagrams are there.
Posted on Jun 11, 2009
kel1guy2002
  • 3740 Answers
Hi and welcome to FixYa, I am Kelly
By secondary belt I am assuming you need the deck belt routing. Here is a picture of the front deck belt routing: http://opebycrigby.tripod.com/decks/jd/jdf525.jpg
Thanks for choosing FixYa,
Kelly
Posted on May 04, 2011
A diagram of deck belt on deck 46 inch cub cadet
Look here then when you put in your Model number look under ATTACHMENTS for a parts diagram showing the Belt layout
http://www.cubcadet.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10051&catalogId=14101&langId=-1#/s/CUT/782/
Jul 27, 2014 | Cub Cadet Garden
Replace cutter belt for a Victa Pro 12 ride on
Contact dealership/service center or buy a service manual online
Jan 25, 2014 | Garden
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mower deck clutch cable removal (model 917.28722). Detail provided in manual does not seem to match product. Need to remove this in order to remove deck and replace belt. Belt has squealed since new.
You should not need to remove the deck or the clutch cable just to change the belt.
  • ensure mower clutch lever is in the off position
  • lift the front of the tractor approx 24 or more inches.
  • lower the mower deck as far as it will go
  • locate & remove the cotter pin from the right (discharge) side mower lift arm where it attaches to the rear of the mower
  • release the lift arm from the mower deck to allow it to drop (it will hang from the other 3 points)
You should now have plenty of clearance to change the belt. Remove the belt from the engine pulley first and replace the new belt on the engine pulley last that will make it easier to change the belt.
If this is helpful please vote yes, Thank You!!
Aug 28, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman 42 inch deck mower. Model 917.277611 (2007). LT1000. 16.5hp Briggs & Stratton. Springs on cutter deck assembly broke. Had to re-assemble cutter deck. Re-attached springs and tension arms....
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Aug 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 inch belt diagram
look on deck or under foot pedal there is usually a diagram in those places
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Belt diagram for craftsman 46" model#917258691 I am replacing the secondary belt
belt routing diagrams are sometimes on the underside of the running board [so when you are laying on your back, you can look up and see it, left side usually]. on a 46 inch deck, it's probable that the diagram is on the rear, center of the deck, you can see it by going behind the tractor, kneeling down and looking forward at the deck
Jul 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The newly purchased deck belt turning the blades is extremely loose
If idler is in tact and spring attached, it is likely that the belt isn't routed properly. If you try to route the rear-most portion of the belt around the idler, it will be loose. You must route the front-most portion of the belt around the center blade pully and then around the idler. Just Google "MTD 46 inch deck diagram" and you will go to a Parts Tree site with the proper diagram showing routing.
May 26, 2009 | Mtd Garden
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
