Question about Home
Water runs for 30 seconds, then shuts off - Home
4 Suggested Answers
SOURCE: My vokera linea ag plus domestic hot water cycles
I have the same problems, did you manage to get it fixed and what was wrong?
Posted on Mar 08, 2010
  • 4 Answers
SOURCE: my Flotec pump runs 5 seconds shuts off for 30
fully submerse pump in bucket of water, tilt to get all air bubles out,(keep hose off) plug in and it should work fine
Posted on Apr 03, 2010
ercupa190
  • 12223 Answers
SOURCE: ESTATE etw4300TQO washer runs water for 30 seconds and then shuts off
1) test the timer for defective, however clean the contacts, loose wires or broken repair see the diagram
2) lack of cold water, fix it.
God bless you
Posted on Jul 03, 2012
My hot water keeps shutting off after I start it. It runs like 15-30 seconds. What's up?
Sometimes that will happen if there is not enough (or any) water in the tank. Also, there might be a little air in the water line(s) if you had the thing apart. Keep trying. Good luck.
Jan 24, 2018 | Water Water Heaters
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
2001 chevy prizm fan runs after engine is shut off until the battery is completely drained
Replace the relay its stuck on,water out the exhaust could be condensation.
May 30, 2014 | Vehicle Parts & Accessories
God bless you
Jul 02, 2012 | Estate Top Load Washer
Ha cruiser engine shuts off after running 30-45 seconds
Could be a clogged filter. If it isn't, then next on your list is the fuel pump. Also make sure there is no water in the fuel.
Jun 14, 2012 | Boating
My Flotec pump runs 5 seconds shuts off for 30
Dec 02, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Heater will not stay on
when a heater runs for 30 seconds or les some heaters run or about 1 minute this is mostly a problem with how much water is getting in the heater if is too little the pressure switch cuts the heater off or the high limit switch is shutting off the boiler why because the small amount of water getting inside your heater get hot to fast and make the heather to get so hot and the high limit switch turns the heater off the solution is to check your filter make sure is clean or cleaned they get dirty soon if your filter is clean and still doing it check the bypass in the heater normally is located next to the lines going in and out in the heather lines I have fix so many heaters my self I use to have a business in california as swimming pools repair so I know this and your heater is not to big to say is your gas regulator gs regulator is a common problem on heaters ranging on size from 30-36-40 BTU
Jun 14, 2009 | Pentair Minimax NT Heater
Home Logo
46 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
