Question about Whirlpool Washing Machines
The agitator on my Whirlpool washing machine isn't working properly. It is moving a little bit but not fully, any help?
The aggitator isn't working properly it is moving a lil bit but not fully help whirlpool lce4332pqo or pq0
    Problem Solver:
  • 19 Answers
You may have worn out agitator dogs. Those are replaceable parts. Not sure which model you have, but if you google for:
whirlpool agitator dog replacement
you should get plenty of hits.
Posted on Apr 02, 2015
GE Top Loading washer doesn't aggitate properly.Model # WJSR4160DW
Reach into the washer and try to turn the agitator by hand and if you can turn it freely the agitator coupling (sometimes called the air bell) is stripped out. If that isn't the problem let me know. Here is the part should you find it bad.
Nov 02, 2012 | GE Washing Machines
Whirlpool lsq8243h doesn't aggitate
if it doesn't agitate but will spin it is probably the agitator cams.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285809/470910
If it doesn't spin it is probably the motor drive coupling
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem.
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
Oct 07, 2012 | Whirlpool Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How to remove aggitator from center of machine to clean inside of it, there seems to be little bits of whatever coming from there its a whirlpool super capacity plus 8255e commercial quality
Pry the top lid off the agitator.
Remove the plastic shield inside.
Use a 7/16 socket and extension to remove the bolt.
Pull the agitator off the shaft.
Mar 04, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Top agitator does not move on a whirlpool LSN100KQO Ultimate Care II commercial washer. how can i repair that?
I have run into the same problem and spent some time with it. There are little pieces that catch and release the top aggitator called dog agits(dogs). They are cheap and easy to replace but the problem is this aggitator is put together so that the top and bottom piece do not come apart. I dont know how this will resolove.
Oct 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Calypso Topload washer Won't aggitate correctly
Possibly a belt issue take the top cover off of the agitator and remove the bolt that holds it down. There will be gears inside if any of these parts are broken this will also cause it not to agitate. Let me know
Jan 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
