Question about Crock Pots & Slow Cookers
Can i replace the safty valve in the lid - Crock Pots & Slow Cookers
    Sergeant:
  • 266 Answers
Check with the manufacturer at it's web site.
Posted on Apr 01, 2015
Pressure cooker won't unlock even after being shut off for four hours. How do I get it open
try releasing the vacuum by removing the pressure valve from the lid first
as it cools and the pressure is not released , a vacuum is created and the lid will be hard pressed onto the seal
Jan 24, 2017 | Crock Pots & Slow Cookers
Why wont my pressure cooker retain any pressure
bad lid seal --lid not put on properly--safety valve not on lid
Dec 07, 2016 | Crock Pots & Slow Cookers
The handle to the lid melted. My fault, I tried to use the insert and lid in the oven. Is it possible to buy a replacement?
Melted my Crock Pot lid handle : slowcooking - Reddit
https://www.reddit.com/.../slowcooking/.../melted_my_crock_pot_...
RedditJul 23, 2015 - So I melted the Crock Pot lid handle.... I....it.... it all happened so fast. Then I messaged Crock Pot to see if they would mercifully send me a...
I have A proline slow cooker, unfortunetly the handle melted ...
www.fixya.com/support/t10606247-proline_slow_cooker_unfortunetly
Oct 3, 2011 - Question about Crock Pots & Slow Cookers. Open Question ... slow cooker, unfortunetly the handle melted last night and came off the lid. can I ...
Slow Cooker Replacement Parts ' Crock-Pot
www.crock-pot.com/parts/
Shop slow cooker replacement parts from Crock-Pot. Make sure your slow cooker is functioning ... Replacement Lid - Crock-Pot® 5-Quart Round Slow Cooker.
Crock-Pot® 4-Quart Oval Slow Cooker Replacement Lid ...
www.crock-pot.com/lids/...lid---crock-pot...slow-cooker/129960-000-00...
Feb 08, 2016 | Crock Pots & Slow Cookers
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    Se e4 on my cooker what do i do
    The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
    Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
    Just bought the 5 Qt electric pressure cooker. Tonight is the first time I'm using it. Got two questions.....is the pressure release valve supposed to be so loose? I'm also seeing steam and condensation...
    Your gasket is no good and needs to be repaired. The water is supposed to be pressurized as high heat steam and when pressure is excessive the valve does its thing to lower to acceptable levels.
    Aug 31, 2017 | Wolfgang Puck Electric Pressure Cooker...
    Displays E2 and E4 (5 qt Wolfgang Puck pressure cooker - silver) what section is problem mechanical or electronic?
    I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
    Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
    Jul 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
    Displays e4 wont work
    Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
    May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
    Need a Replacement Lid for Rival's Oval Smart Pot Crockpot
    I found something on amazon,click here and take a look: Amazon com rival replacement lid. I hope this was helpful. Cheers
    Nov 17, 2008 | Rival 38601 Smart Pot 6-Quart
    Crock Pots & Slow Cookers Logo
    107 people viewed this question
    Top Crock Pots & Slow Cookers Experts
    tsalagi152
    charles
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
